Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
Since I've had several Toyota transmissions apart now and was seeing a pattern, I took a bunch of measurements of the shafts and gears. Turns out all of the C-series gears are cross-compatible! Read more about it on my blog...
http://www.armstrongfamilyblog.com/a...nsaxle-options |
![]() ![]() ![]() Drives: 2018 Yaris SE 5MT Join Date: Aug 2017
![]() Who knew you could get a C-series dogbox?!? Assuming you have a spare $6k sitting around. lol Interesting read, thanks Tom! -- Adam |
Good to know!
No one ever wants to give a Yaris the point by... ![]() |
2ZR swap. DO IT! Ask how!
I did a less detailed investigation several years back when I built my gearbox, but came to the same conclusion for the C5x gears. That's how you get the super overdrive 5th gear and closer 1-2, 2-3 ratios. =)
Data doesn't lie
Yes that’s correct! If it wasn’t for you and Bluevitz tearing into these gearboxes before me, I wouldn’t have been so interested to do further research. So thank you!
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 07-08-2018 at 08:35 PM. |
#6 | |
![]() ![]() ![]() Drives: MR2 Spyd/Type R/Yaris/Civic Si Join Date: Feb 2007
![]() someone teach me how. I hate the huge bog between 1-2 and 2-3, but I love the relatively low hwy rpm in my 2010 CDN model Yaris. teach me ![]()
https://www.instagram.com/3cyltrbo/ |
Watch Armstrong's YouTube videos on rebuilding a C60 gearbox. Same basic idea, just has the extra gear on one end. =)
Data doesn't lie
Thanks Sam! I have made it my purpose to put out a bunch of Toyota gearbox info in writing and video form. I hope to show everyone how to modify these gearboxes or possibly entrust me to build some for the community. So for Trevor and Taylor are the only people to receive gearboxes from me....let’s change that!
Awesome stuff!!
I was the one that built and documented the c160 conversation for the first Gen platform.
![]() ![]() Drives: 04 3dr HB and 04 5dr RS Join Date: Mar 2018
Is this documentation still around for the first gen? I want to do a 6 speed and a LSD this winter........
#12 | |
Yup
#13 | |
Data doesn't lie
Thank you for showing us the way with the 6-speed brother! |
#14 |
![]() Drives: NCP131 Join Date: Oct 2018
Hi Guys ,
I am planning to use C150 gearbox 3rd 4th 5th gear set to C56 , are these gears same in size ? Can I use the C56 synchronizer and slider ? Thanks in advance |
#15 |
Awesome work, its a shame the C trans wasnt used in conjunction with some of the bigger v6s and i4's
i think those where E coded tranS. |
Tags |
final drive, gear ratio, lsd, transmission |
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
2015 Toyota Camry | Kal-El | Off-topic / Other Cars / Everything else Discussions | 9 | 04-18-2014 06:47 PM |
Gear fault on a 2009 manual toyota yaris please help! | Gretch2689 | UK | 1 | 03-06-2014 01:41 PM |
Close ratio gear kit | Vanquisher | Performance Modifications | 8 | 09-01-2010 12:18 PM |
