Old 05-31-2007, 11:10 AM   #1
Yaris Revenge
GIGA...DRILL...BREAKER!!!
Yaris Revenge's Avatar
Drives: Lagann. ;P
How to determine proper wheel offset?
I know, I know, I don't even own a Yaris yet, so why am I asking silly questions?
PURSUIT OF KNOWLEDGE!
I was just curious how in the world you even start to choose your wheel offset? Does the dealer offer you recommendations, or do you just have to guess, or what? Is there a formula based on your total tire diameter and width? Inquiring minds wanna' know!
I did use the search function, but only found tips on specific tire/wheel combos. I'm looking for info that will help me figure this stuff out on my own when the time comes.
~YR
Be polite. Be professional. But have a plan to kill everyone you meet.
Yaris Revenge is offline   Reply With Quote
Old 05-31-2007, 11:27 AM   #2
Take a look at this fitment worksheet for technical data. It's the best wheel fitment sheet I've ever seen, and FIKSE is a major player in custom race wheels.
http://www.fikse.com/fitment.html
Now, for the Yaris, the pictures of wheels on here with +40mm offset look very close to the fender (and pretty good, too!) so I would say that is the minimum or close to it. The guys at WheelGuyz.com didn't want me to get a wheel with an offset in the 30's, he thought that would stick out too much. I'm getting rims with a +43mm for just a little more "tuck".
The smaller the offset the more the wheel "sticks out".
Please jump in and correct me if I've got any of it wrong.
Old 05-31-2007, 11:28 AM   #3
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Totally depends on diameter and width. For a 7 inch wheel anything from +45 to + 40 will work. You can go lower than that but it will depend on your ride height.
I have 16X7 +40 with 205 50 16 tires. Pics in my garage.
Old 06-01-2007, 08:23 AM   #4
grampi
Drives: Corolla
Pics in your garage don't do us any good How bout posting some pics in here?
grampi is offline   Reply With Quote
Old 05-31-2007, 01:22 PM   #5
As a reference, if you take a look in my garage, I have 7.5" wide rims and a 42mm offset at the back, while the front has an estimated 38mm offset (the brake discs mounting plate thingies are thicker than stock). But remember my tires are stretched a little bit, if they were wider they would rub up front for sure. 40-42mm would be perfect for this wheel width.
Old 05-31-2007, 07:21 PM   #6
etimago, are those 17" rims, or 16's?
Old 05-31-2007, 08:13 PM   #7
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
before worrying about offset, measure from your fender down to your tire, this will determine how much you need to lower the car to lose that terrible case of wheel gap
now offset, measure the distance from the tire to the inside of the fender and this will determine how large of an adapter you will need, be sure and compeltely fill this space also
now you have a rad ride
don't concern yourself with rubbing because damnit you look good doin' it
SPONSORED BY
Old 05-31-2007, 10:46 PM   #8
Black Yaris
der Zeck
Black Yaris's Avatar
I am running 215/40R17's with a +42 offset
the OE wheel is 15X5.5 with a +38
if you are going to lower your car I would not go much wider than 7.5 inch wide wheel and keep it in the +40 to +45 range and don't go any wider than a 215 tire and you should be fine.... click on my signature for some wheel tire combo choices
Old 05-31-2007, 11:00 PM   #9
kimona
kimona's Avatar
Drives: 2014 White VITZ
I believe Toyota Yaris OEM alloys are as follows:
15 x 5.5 ET45 (185/60/15)
16 x 6 ET51 (195/50/16)
This is the info I got directly from Toyota Japan.
If anybody has information to the contrary, then please post.
Old 06-01-2007, 10:57 AM   #10
kimona
kimona's Avatar
The pics in largeorangefont's garage seem to show that his wheels are at the outer limits (particularly up front).
Would it be safe to post that 7's with a ET+40 is about the lowest offset we'd want to run without having the front wheel/tires stick out a bit?
Old 06-01-2007, 01:43 PM   #11
You can also get more information by playing around on here:
http://www.rims-n-tires.com/rt_specs.jsp
It will guide you to how well different widths and offsets will fit compared to OEM whels.
Old 06-05-2007, 04:42 PM   #12
Yaris Revenge
Drives: Lagann. ;P
Thanks for the info guys!
~YR
Old 05-23-2009, 04:39 AM   #13
xbalance
Drives: stock
im using yaris sedan will there be any issue with offset +45
as i plan to use racing hart cp35 195/50/15 wheels
worries it will rub the front wheels...
what is min-max offset i can go?
xbalance is offline   Reply With Quote
Old 05-23-2009, 09:02 AM   #14
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
just look for the official tire and wheel thread...
Old 05-23-2009, 10:41 AM   #15
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
+45 offset is way in... no problems there... when you get to 30.. it starts to look pretty nice and lined up with the fender
Its a Chao!!!
Offset and lowering on 205/45/16s driver centric Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 08-13-2016 10:09 AM
PLEASE HELP! 15x8 wheels contraband831 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 76 06-30-2007 10:34 AM
PIMP Wheel for the yaris EnduroMTS Sponsors Classifieds Area 32 11-06-2006 05:23 PM
20" wheel question mikeukrainetz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 10-25-2006 11:22 PM
Question about wheel Offset monoculusjoe Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 09-07-2006 03:03 AM
