Old 07-12-2018, 01:31 PM   #1
RicStyx
Drives: 2012 Toyota Yaris 1.3 -3rd Gen
Engine tuning
I recently enquired with a reputable engine management tuning company as to see if there is anything they can do. They have a software which is dyno tested before and afterwards for proof on the yaris and is very moderate in terms of power gains.
I have heard our yaris ecu's don't like to be tuned and can cause issues. Has anyone else had a problem with any tuning of there systems?
Sent from my SM-N910F using Tapatalk
RicStyx is offline   Reply With Quote
Old 07-13-2018, 03:23 PM   #2
DarkShadowFox
uh whats the name of the tuning company and where are they based out of.
Old 07-13-2018, 06:26 PM   #3
RicStyx
There based here in South Africa. Called ATM tuning
Old 07-13-2018, 04:08 PM   #4
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
The general consensus seems to be that using a piggyback or replacing the ECU is the way to go.
On Instagram
On Wheelwell
Old 07-15-2018, 11:28 AM   #5
DarkShadowFox
this /thread
Old 07-15-2018, 11:45 AM   #6
tmontague
tmontague's Avatar
Even then piggybacks have been reported to essentially lose their tune as the stock ecu sometimes "relearns" itself. This has been well documented on corolla forums. The first gen Yaris' (echo's) don't have an afr sensor and piggybacks work fine on those which makes going turbo much easier from what I have read and discussed with people
If your country allows standalone ecu's and it keeps it road legal then go with a standalone ecu that your local and trusted tuner if familiar with. This will make it much easier to tune the engine the way you want
Old 07-15-2018, 06:05 PM   #7
DarkShadowFox
put a 3rd gen yaris body over a 1994 corolla chassis call it custom body work done.
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
Check engine light + vibration Lisbeth DIY / Maintenance / Service 12 04-05-2020 09:28 PM
Engine Delayed Start - Toyota 1NZ-FE 1.5L SL Runner General Yaris / Vitz Discussion 9 07-23-2011 03:13 PM
