![]() Drives: 2014 Yaris I Join Date: Aug 2018
key FOB?
I just bought a 2014 Yaris and the keys had a black plastic thing, A fob? that looks to have no button. Does this FOB have any function?
やりすぎだ~
Usually there is a chip in the black thing. The Yaris will read the chip when you insert the key into the ignition to start it.
If you made a duplicate key without a chip and tried to start the car, the starter will crank, but the engine won't start. A regular key (no chip) will run $5.00-$10.00 a chip key will be around $80-$100 because the chip must work with the car for it to start up correctly. |
Drives: 2015 Yaris LE 3door 1F7 Join Date: Feb 2017
it is separate from the key. The build thread would not work.
| Question about adding another key and fob | rcvmini | DIY / Maintenance / Service | 19 | 10-14-2018 10:17 PM |
| New remote key fob programming | costica | DIY / Maintenance / Service | 1 | 04-17-2016 09:02 PM |
| Replacement key for fob? | jorwex | General Yaris / Vitz Discussion | 2 | 03-18-2016 07:57 AM |
| VItz 2010 Push Start Fob key Programming (Duplicate Smart Key). | ahsanraza | Performance Modifications | 1 | 02-03-2016 07:29 PM |
| Transponder key programming | teddy | DIY / Maintenance / Service | 6 | 04-28-2015 07:32 PM |
