Old 09-27-2018, 11:08 PM   #1
redbean
Drives: 09 Yaris hatchback
Can I install an old school Toyota tape deck into a 2009 Yaris?
Is there any reason I couldn't, say, buy something like this 98-02 Toyota Corolla Rav4 Tacoma Radio Cassette Tape 86120-04090 A56409 LK31 and install it? I found a pdf with a pinout here that says "1987 and newer." It looks exactly like the plugs behind the head unit in my Yaris, and exactly like the two plugs on the right hand side of the back of that tape deck.
Assuming I don't care about brackets / mounting, if I just plug it in, will it work? Should I be scared? Have they really changed the design that much?
redbean is offline   Reply With Quote
Old 09-27-2018, 11:20 PM   #2
Dodge Aries K
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback
You'll lose your aux port but yes, it will work.
I would search a bit more because I'm pretty sure they have the right shape one from a slightly newer Corolla or Camry that has a tape and CD player that will fit perfectly.
-Karl the Uber/Lyft Driver
Dodge Aries K is offline   Reply With Quote
Old 09-27-2018, 11:22 PM   #3
Dodge Aries K
https://www.ebay.com/itm/Toyota-Echo...haxDDS&vxp=mtr
Here, this will fit perfect and work just fine. Just without aux support.
Old 09-28-2018, 10:56 PM   #4
redbean
Awesome, thank you. I also have a 98 Camry and a lottttttt of tapes. Maybe I'll check around at junkyards and see if I can find one of those. Should I be able to use anything I see with those connectors?
Old 09-29-2018, 08:37 AM   #5
IllusionX
Drives: 07 Yaris Sedan Aero
Should be. But last time I tried plugging a casette HU from an 98 Corolla, it didn't work.
You might need to double-check the wiring just to be sure, cuz it didn't work anymore afterwards.
Sent from my VTR-L09 using Tapatalk
TOYOTA YARIS 2005, How to install AUX compatibility? krs123 Performance Modifications 0 02-04-2015 05:52 PM
2009 Toyota Yaris LB DandiDani Cars for Sale by private party 1 12-08-2014 10:24 PM
2009 Toyota Yaris Sedan, Low Miles, A/T, Very Clean redoctane Cars for Sale by private party 0 08-18-2012 04:24 PM
