![]() Drives: 2018 Yaris iA Join Date: Sep 2018
No Warranty on Jack - Use at your own risk
Hi everyone. I found this out today, and thought it important enough to share.
Toyota does not warranty the standard jack that comes with the 2018 Yaris iA. I had the jack fail while it was being used by a police officer. The jack bent and was unable to fully raise the car. Toyota offers no warranty, but will replace the bent jack part (not the entire jack) in the name of 'customer satisfaction'. I'm just going to get a small bottle jack and keep that in the trunk, and I strongly recommend that every Yaris iA owner do the same. Don't take silly risks with a weak jack. |
![]() ![]() ![]() ![]() Drives: street-legal go-kart Join Date: Oct 2008
Thanks for the heads-up
1. Keep a hi-visibility vest with your spare along with a powerful flashlight/lantern(flat tires can happen any time-day or night). 2. I keep a small 2x4 with my kit to chock a wheel on the good axle. Those scissor jacks will bend if the car shifts weight. 3. Loosen the lugs BEFORE raising the vehicle. A metal pipe a couple feet long can be used as a breaker-bar for the usually-tiny lug wrench if you have one in your custom kit. 4. Every once in a while check your spare's tire pressure. Check the others while you're at it! 5. Finally, if you don't feel comfortable doing it yourself call your insurance company, AAA, or local authorities. I'm not saying you did anything wrong. Just thought it would be a good reminder to everyone since we were already talking about the jack
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
Never used the jack. No flat on the road and I use floor jacks to rotate tires. Good information.
Making a decision without following it with an action is still a fantasy. |
#4 | |
![]() ![]() ![]() Drives: '08 Yaris LB Join Date: Jan 2012
| No Warranty on Jack - Use at your own risk | DallasDiy | New YARIS Purchase Forum | 3 | 11-26-2018 09:05 AM |
| DIY: Aux Input Jack Adapter | TinyGiant | DIY / Maintenance / Service | 11 | 11-10-2012 06:33 AM |
| Warranty Information for US Yaris Owners | AdeJong 03 | General Yaris / Vitz Discussion | 4 | 09-19-2009 11:14 PM |
