Old 09-30-2018, 10:32 AM   #1
Yaris709
Drives: 07 yaris
Transmission line leak
Hey guys posted a while ago about having a transmission leak which i thought was from the pan gasket but upon further inspection its from one of the trans. lines going to the radiator. Is this an expensive/hard fix? It's not the rubber hoses but from the steel lines.
Yaris709 is offline   Reply With Quote
Old 09-30-2018, 10:51 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
Pictures?
AFAIK, transmission oil is not cooled in the Yaris? I might be wrong..
Are you sure it's transmission oil?
Oil might be dripping to the AC line?
Sent from my VTR-L09 using Tapatalk
Old 09-30-2018, 11:18 AM   #3
tmontague
tmontague's Avatar
You can buy a new hard line but chances are the small 10mm bolts holding it on are rusted and will shear off.
This happened in my '05 Vibe. I purchased some rubber oil lines and just used those to run to the trans cooler in place of the hard lines. I then used the figure 8 zip tie method to keep the lines from rubbing together or rubbing anything else. Has so far worked well for the past 25,000km
Old 09-30-2018, 05:59 PM   #4
Yaris709
Drives: 07 yaris
Oh its definitely transmission fluid! Theres 2 lines that go to the radiator from the transmission. And I've been slowly having to top it up every couple weeks or so depending on how much driving I do. It's hard to get a good look at it for a picture. I'm hoping it's an easy fix.
Transmission leak. big time!!! misterno General Yaris / Vitz Discussion 6 05-15-2016 03:47 PM
Installing a external in line transmission filter. YarisSedan Performance Modifications 1 03-31-2009 08:03 PM
