![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
Quick orange flash under rpm needle?
I took a flashlight and looked into cluster but dont see an icon where light is comming on.
Maybe I am seeing things?Its just a quick orange flash know and then.LIke I said its just underneath the rpm needle in line with the other icons. |
A picture and circle where you see it might help..
Sent from my VTR-L09 using Tapatalk |
![]() ![]() ![]() Drives: '08 Yaris LB Join Date: Jan 2012
Low washer fluid?
Misfire making the check engine light flash? |
It is in this area.Thing is I see no icon/outline when I shine light.
https://i.imgur.com/3AzSAwL.jpg |
![]() ![]() ![]() ![]() Join Date: Feb 2010
you should be able to see the symbol when you start your car before it goes out. I would then refer to your owners manual to see what it is. Could be washer fluid or the alternator/battery. You could also just top off your fluid and see if the light stops flickering if you don't have the owners manual.
![]() Drives: Yaris 2007 Hatch Join Date: Apr 2018
99% you're on low washer fluid. When you hit a bump or something, it briefly goes under the sensor level.
#7 | |
I'm going out on a limb here and saying you're seeing things... ;)
So did the op ever figure this out
| Toyota Yaris Optimal RPM for Highways | Anquietas | General Yaris / Vitz Discussion | 12 | 04-28-2017 05:59 AM |
| IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 | RPM JEFF | Great Lakes | 0 | 09-24-2012 04:40 PM |
| IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 | RPM JEFF | Mid-Atlantic | 0 | 09-24-2012 03:10 PM |
| Yokohama Orange, You Glad? | Yar Is Word | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 08-24-2010 09:29 AM |
| Source code for Yaris Tachometer | metalshark | DIY / Maintenance / Service | 27 | 04-06-2009 12:41 AM |
