Old 02-02-2019, 09:57 PM   #1
firebird1999us
firebird1999us's Avatar
Drives: 2003 Mach 1
Are there any hood or battery clearance issues with the Ultra racing strut brace
I was considering this one to go with the suspension redo the Yaris is undergoing:
http://ultraracing.my/ecatalog/index...t-tower-bar-2/
firebird1999us is offline   Reply With Quote
Old 02-03-2019, 08:30 AM   #2
For 99.999% of Yaris owners, those things are just engine bay bling. Put your money elsewhere.
Sent from my EML-L09 using Tapatalk
Old 02-03-2019, 05:37 PM   #3
myfirstyota
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped
Put that money toward better tires
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61427
Bolt-in 3.75" Suspension Lift Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61577
myfirstyota is offline   Reply With Quote
Old 02-03-2019, 05:40 PM   #4
tmontague
tmontague's Avatar
Imho its isnt beneficial until you have tires that can hold much higher g's in a corner and stiff custom spring rates. Those spring place much more stress on the chassis and that is where the strut brace is beneficial.
Like others said it's just bling for the vast majority if yaris owners as what I said above it not even possible on public roads unless you're trying to get put in jail.
To answer your question though it would be a tight fit if you have a group 35 (or 36, I can't remember) battery as opposed to the 26r that comes with the car which is slightly shorter iirc.
Old 02-04-2019, 07:29 PM   #5
firebird1999us
Drives: 2003 Mach 1
Ive got a duralast Gold in there at the moment.. I’ll have to look and see what type that is. Would it be labeled on the battery?
Old 02-06-2019, 07:20 PM   #6
tmontague
tmontague's Avatar
Yup typically right on the top where it shows CCA and overall amperage
Old 02-07-2019, 08:20 AM   #7
firebird1999us
Drives: 2003 Mach 1
Awesome! I'll take a look at it!
Old 02-03-2019, 06:43 PM   #8
I've not seen any tower brace having issues with battery clearance. What I believe you can guarantee is the hood support rod is rendered useless.
Buying aftermarket battery caineroad DIY / Maintenance / Service 57 02-14-2016 07:17 AM
FS Cusco coilovers, ultra rear sway, gt spec bracing, miracle x cross bar seibon hood blacksandiegovitz Items for Sale by private party 23 10-24-2015 11:47 AM
2001 Toyota Vitz RS Front Strut Brace mistervitz General Yaris / Vitz Discussion 7 10-23-2008 12:36 PM
ultra racing front strut bar installed smurf Performance Modifications 9 03-10-2007 05:58 PM
