![]() Drives: 2005 Yaris Join Date: Mar 2019
Engine light on code P1345
Engine light won’t go out - at first the initial code said fault crank sensor, light still on. Next code said cam sensor, light still on. Then code P1345 said VVT sensor. Replaced it (albeit with cheap Chinese part) - engine light still on and comes up with same code.
Car runs well at all revs including idle! Any ideas would be welcome Al |
Have you actually performed a code reset, or just hoping they will go away because you dealt with the issues?
Sent from my EML-L09 using Tapatalk
Yes I have re set the engine codes
| SRS Light On (B1805/52 Code) Even after having recalls done | fourbangingfun | DIY / Maintenance / Service | 3 | 10-07-2017 11:48 PM |
| Engine light came on but seems to run fine | naossoan | DIY / Maintenance / Service | 7 | 06-10-2013 04:51 PM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| Anybody know the code? | Driver | New YARIS Purchase Forum | 5 | 08-20-2006 06:56 PM |
