Drives: Yaris 2003 Join Date: Mar 2019
Water in the boot
Hello everyone,
I have seen some similar posts, but my case looks slightly different. This is why I am opening a new topic. I have a leak in my trunk. I found it out when Iooked under the boot floor cover - there was water in the spare tire bay and the left side of the floor mat was wet. I replaced the left taillight gasket. It does not leak that much now, but the problem persists. It does not leak from the under. There is a sunroof, but I do not think it leaks through there. It leaks only when I use a hose and spill the water on the hatch. The hatch has 2 metal sheets welded from inside - it somehow leaks through there. https://www.youtube.com/watch?v=yHLlXxZCwgg Any ideas? Change the taillight seal one more time? Thank you, Bart |
Could be from the glass, or the boot "door" seal? Not sure where you are hosing down from.
Sent from my CLT-L04 using Tapatalk |
![]() ![]() Drives: 2008 Yaris 3DR Hatch MT Join Date: Dec 2018
No different than the other 200 posts about leaks. Everybody's Yaris leaks. If you want a Yaris that doesn't leak buy a Fit. Welcome to the club.
Tail light gasket
The tail light gasket may have relaxed. Only two nuts on one side snug it down...it needs at least three. I nearly eliminated major leakage both sides just by cleaning up everything and re-using original gaskets (No sealant added, but I MIGHT have lightly greased them...which I'm not recommending)
Check the nuts. My sense is that it is better not to squeeze the crap out of a brand new gasket, but rather snug it down incrementally over time. |
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped Join Date: Feb 2016
Basically the only downfall of this car. Leaky McLeakerson
No one suspects the Yaris. Xd/2zr-fe Swap/Build Thread http://www.yarisworld.com/forums/showthread.php?t=61427 Bolt-in 3.75" Suspension Lift Build Thread http://www.yarisworld.com/forums/showthread.php?t=61577 |
Hi guys,
I have already removed the tail light, cleaned it and applied silicone on the original gasket. When I spill the water directly on the rear light it does not leak. It leaks when I spill the water above the rear light, at the top of the hatch. In your case, when the leak was from the tail light - where did the water come out? Was it clear the leak is from the lights? |
#7 | |
![]() ![]() Drives: Yaris T sport TRD turbo Join Date: Aug 2017
2004 Yaris T-Sport 1NZ-FE with TRD Turbo |
Yaris hatch leak tail light
There is a joint in the overlapping spot welded tin where the gutter dumps rearward (above the taillights). I also cleaned up that area when I did the taillight gasket...but didn't add caulk or anything up there. The gutters themselves are smooth and crack free.
I still get dripping from the hatch raised some time after a rain, as if water got into it...starting to wonder about small shields at hatch top corners trapping water and letting it into the hatch through the holes for the clips. |
| Water leak/removing rear seats | Sarah1986 | DIY / Maintenance / Service | 1 | 12-12-2016 06:38 AM |
| Location of Water Pump | lululovesu | DIY / Maintenance / Service | 1 | 10-19-2014 08:05 AM |
| water in the tails? | the_boss | Cosmetic Modifications (Exterior/Interior) | 9 | 02-20-2009 12:53 PM |
| Shift Boot ... revisited | bigsky2 | Cosmetic Modifications (Exterior/Interior) | 35 | 04-19-2007 07:04 AM |
