Old 05-30-2019, 11:09 PM   #1
justanotherdrunk
justanotherdrunk's Avatar
Drives: 2016 SE
Anyone install LINUX over Win 10 ?
so far ive failed on 2 machines
used rufus to burn the free downloaded LINUX to a bootable usb stick
successfully changed booting order to boot from usb stick
both machines an old desktop and a newer laptop then crashed
just a novice here
Old 05-31-2019, 06:36 AM   #2
What linux distribution? At what point did the computers crash, did you see any kind of linux loading screen first?
Old 05-31-2019, 07:27 PM   #3
justanotherdrunk
Drives: 2016 SE
this is what i tried to install
http://wikka.puppylinux.com/HomePage
looks like something tried to install then defaulted back to win 10
no indication of program loading
Old 06-01-2019, 12:02 AM   #4
it's pretty hard to say :D My hunch is that it's something related to BIOS/UEFI. When you burn an image in rufus there are several options (partition scheme, target system...). If you computers are older, they may support BIOS only and not UEFI. Anyway, it's probably goign to take a lot of trial and error to figure out, good luck!
Old 06-01-2019, 02:42 PM   #5
justanotherdrunk
Drives: 2016 SE
thanks
Old 06-01-2019, 06:59 PM   #6
IllusionX
Drives: 07 Yaris Sedan Aero
I mostly use Ubuntu, because support.
Not once it failed me. But I never install alongside windows.
Sent from my CLT-L04 using Tapatalk
Old 06-02-2019, 02:44 AM   #7
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
I agree, Ubuntu linux is the distro to use. If you just want to try it, you can boot into a live Linux session straight off the boot media.
If you decide you wish to install it, you will also need spare space on the hard drive that is not part of a partition. You can use a tool such as Partition Wizard to shrink the Windows partition and create empty space for Ububtu to install.
Because I had a spare, I actually installed Linux on a separate hard drive. I can then use the BIOS boot selection when I want to boot Linux. Windows will not mount the Linux drive partitions without extra software, but Linux can access the Windows drive.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 06-02-2019, 11:37 AM   #8
justanotherdrunk
Drives: 2016 SE
Old 06-15-2019, 12:45 AM   #9
justanotherdrunk
Drives: 2016 SE
solved
not install over win 10 but alongside
once i partitioned some disk space it installed no problem
thanks
Old 06-15-2019, 05:47 PM   #10
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Originally Posted by justanotherdrunk View Post
solved
thanks
Now the learning begins...
Admittedly I have been using various Linux versions for years. The initial learning curve is steep, but you reach a point where it all seems very logical. I also still look up solutions on internet from time to time when asked to make some new changes on the servers.
Old 06-15-2019, 07:11 AM   #11
awesome!
))) Tein Super Compact coilover install tips ((( aucorium DIY / Maintenance / Service 4 10-25-2011 12:42 AM
HELP needed for carputer project: Powered USB hub install Astroman In Car Entertainment + Electronics (audio / video / alarm) 15 11-01-2010 05:18 PM
where can i install these power locks? songa New England 1 12-04-2008 12:41 PM
