Old 06-03-2006, 09:35 PM   #1
YotaYarisUSA
Drives: Yaris Sedan,Pacific Blue
ipod aux cable
Can someone please, give me the name of the cable I need to hook up my IPOD to my Yaris? I've tried to find the cable on apples website and maybe I'm just not looking at the right cable, they have some many thinks and must of them seem to be FM converter cables,but now that I have the AUX jack in the yaris thats all I should need,if I can just find the right cable.
Thanks,
YotaYarisUSA
YotaYarisUSA is offline   Reply With Quote
Old 06-03-2006, 11:02 PM   #2
eight_heads
eight_heads's Avatar
Drives: '07 Yaris Liftback
you can get one at radioshack.. it just looks like a heaphone plug on both ends
'07 Yaris Liftback
-Red 5spd w/convenience
eight_heads is offline   Reply With Quote
Old 06-25-2006, 11:20 AM   #3
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Exactly what Eight_ said.
It cost me $4.95 at Radio Shack, and it sounds perfect. Some cars/trucks, you need the more expensive adapters to help boost the line level signal, or you will have to CRANK you iPods volume just to hear something.... not a problem for the Yaris!
Old 01-23-2007, 12:30 PM   #4
djfuji
djfuji's Avatar
Drives: 2007 Meteorite Metallic
i got that cable at radio shack, but when i plug it in it only comes through the left speakers... help?
djfuji is offline   Reply With Quote
Old 01-28-2007, 10:25 PM   #5
H2XcapePod
Drives: 07 Yaris LB
6ft audio cable
Ran it under the shifter console, under the steering wheel, into the door where the pod mounts on the armrest. Oh so ergonomic!
H2XcapePod is offline   Reply With Quote
Old 01-29-2007, 01:11 AM   #6
IsLNdbOi
IsLNdbOi's Avatar
Do the ends of the cable have one black ring? If so, you got a mono cable instead of a stereo. You need one that has two black rings on each end of the cable. Or maybe your speaker balance is all the way to the left speaker only?
Old 06-03-2006, 11:37 PM   #7
Idjiit
5 Stars, Bitches
Drives: Prius, Silver Yaris Liftback
It's a stereo 1/8 inch plug.
Idjiit is offline   Reply With Quote
Old 06-04-2006, 03:35 AM   #8
echo_hrs
Around the universe...
Drives: Uber-Evolved Pokemon
I made my own AUX cable, i didn't need a 6 foot cable, so i hit a REAL (read ; Radio Shack blows for the DIY'r) electronics supply store, got my connectors, solder and wire, and made me a nice short 1/2 footer...
Of course, i also made a custom AUX port on my Yaris because us Canucks didn't get one...
Cheers
echo_hrs is offline   Reply With Quote
Old 06-11-2006, 12:26 AM   #9
paco
Drives: 2002 MINI Cooper
Cheers
echo_hrs: I know you now have a Clarion head unit.
It is possible to build a custom AUX input for the factory RS head unit ? If so, how did you do it ?
Thanks,
paco
paco is offline   Reply With Quote
Old 06-11-2006, 12:43 AM   #10
eight_heads
Thanks,
paco
you can do this with a fm modulator... something like this http://cgi.ebay.com/110-ch-wired-ste...QQcmdZViewItem anyway, it basically goes inline with your radio antenna and takes over a specific channel when it is on...
'07 Yaris Liftback
Old 06-11-2006, 01:23 AM   #11
eight_heads
echo_hrs, i noticed in your pics that it looks like your pedal arms are plastic.... is that so or are they metal?
'07 Yaris Liftback
Old 06-11-2006, 09:37 AM   #12
echo_hrs
I think the clutch and brake are metal, but the Gas Pedal is plastic moulded into the shaft...I have since replaced my pedals...
Cheers
Old 06-11-2006, 09:57 PM   #13
suzu
Drives: 3dr lb
This works best for me
YotaYarisUSA, this works best for me. i would like to know if someone has successfully used the folder and text buttons on the factory stereo with MP3 files and with what cables?
http://catalog.belkin.com/IWCatProdu...duct_Id=178147
suzu is offline   Reply With Quote
Old 06-12-2006, 01:15 AM   #14
Tankota
Prototype Tester
Drives: Yaris S-Sedan / FJ Cruiser
If you are looking to control an I-pod from the factory radio, it won't do it. All the jack does is a line in. You can even plug a walkman into it or any other audio device with a headphone jack. The MP3 controls on the radio are only for MP3 cd's.
Tankota is offline   Reply With Quote
Old 07-23-2006, 10:59 AM   #15
Chaad32
Chaad32's Avatar
Drives: 2007 Liftback
Cheers
The clutch and gas pedal are plastic, and the brake is metal
2007 Liftback
Blazing Blue
Cold Weather, Convenience Package, Arm Rest,
Floor mats, Weathertech vent visors
Chaad32 is offline   Reply With Quote
Old 07-23-2006, 06:11 PM   #16
Chris07LB
Chris07LB's Avatar
The break pedal is ALWAYS metal on every car.
Old 06-11-2006, 12:46 AM   #17
echo_hrs
As far as i know, the Toyota iPod Adapter for the Yaris in Canada works only on the CE/LE, which leads me to believe that the CD Changer portion of the stock RS stereo is used to control the 6 disc functions...When I pulled the stock RS unit, both connectors were plugged into the back of the OEM RS unit, but when I connected the Clarion, I only needed the one OEM connector, the second (CD Changer I am assuming) was left unused...
You could use and FM Modulator through an FM station but quality would suffer of course...
I just bit the bullet, for the cost of an adaptor (if such a thing exists for the RS) and bought the new deck, which was cheaper than the iPod interface from Toyota anyways...
Cheers
Old 06-24-2006, 08:37 PM   #18
Mattiepl
Drives: 07 Red Yaris 4dr
There is a piece that they make that takes the Ipod plug and gives you the headphone jack for the aux input and 12v power supply for the ipod to charge... I am actually on the way to the place I work to buy one. When I get it I will put a better description for you.
Mattiepl is offline   Reply With Quote
Is MP3 AUX Jack Grounded properly? iseraph7 In Car Entertainment + Electronics (audio / video / alarm) 17 07-16-2009 05:51 PM
