![]() Drives: 2005 Toyota Vitz RS Join Date: May 2018
Hi guys first post in here. Need some help.
Anyone know if I can retorque ARP head studs Without removing the camshafts on 1nzfe? Just about finished run in for new build and Will need to retorque but don't know if cams need to Be removed. All I know is that arp head studs are Made so that they can be retorqued without needing to Remove camshafts but unsure on our engines. Thanks in advance for your help!
![]() ![]() ![]() ![]() ![]() Drives: 2015 H Production Yaris Join Date: Oct 2009
Cams are in the way of the head bolts. We also found we could not use a complete set of ARP studs because the bolts they include are so tall they hit the CAM timing wheel and block the VVTi passage, so we mix them with OE bolts.
2005-2008 SCCA Solo BS National Champion 2017-2018 SCCA H Prod National Champion
Great thanks for your help Jason.
![]() Drives: bB NCP 31 2005 y Join Date: May 2011
1. Потребуется немного сточить клапан vvt-i, потому что шпильки ARP больше в диаметре.
2. Потребуется уменьшить диаметр впускного вала у первой крышки распредвала. Так как гайка ARP слишком высокая. 3. Для замены стандартных болтов крепления головки блока цилиндров распредвалы снимать обязательно. |
![]() Drives: scion xb Join Date: Apr 2020
the 1nz ARP kit needs 3 of the nuts ground down too fit.
ALSO you will need to notch the end off of the VVT-i solenoid as it hits one of the nuts. cut the side of the nut where the socket goes, NOT the side that makes contact with the head. i did not want to use the OEM spring bolts mixed with the ARP as they would apply different amount of load. cutting the top off the nut does not change any properties affecting torquing or loading on the build. the ones that go here need about 1/8" cut off the TOP of the nut. otherwise they hit the cam. |
![]() Drives: yaris ts 2005 Join Date: Jul 2018
Hello guys, can you give me some more specific information about how to notch the solenoid valve without damaging it?
| Tags |
| 1nzfe, arp head studs, forced induction, re-tourqe |
| Want to build costom turbo kit. Need advice from boosted guys! | pimp my yaris | Forced Induction Forum | 639 | 09-28-2013 11:26 AM |
| Chevy Aveo RS: Turbo + good looks = build it! | Thirty-Nine | Off-topic / Other Cars / Everything else Discussions | 22 | 01-12-2010 12:36 PM |
| Turbo Project Yaris TS 1.8L | CASTREX | Yaris TS Talk | 40 | 08-21-2009 10:24 AM |
| build up for a turbo | redduck | Forced Induction Forum | 15 | 07-02-2007 09:31 PM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
