Old 08-28-2019, 03:35 PM   #1
Rob888
Drives: 2010 Yaris 2 door hatchback
How shut off seat belter chime?
I called two Toyota dealers about shutting off the seat belt chime on my 2010 Yaris. Both said that the chime cannot be shut off.
If I remove the chime speaker from inside the instrument cluster are there any consequences to doing so? Will doing so affect any part of the computer system? Will the key reminder and other reminders still work? I have the Yaris Factory Service Manual. Thanks for any replies.
Rob888 is offline   Reply With Quote
Old 08-28-2019, 04:28 PM   #2
Brighton
Knower of little
Drives: None
It can definitely be shut off, I just don't know how they do it. Old people hate those buzzers and they frequently have the dealer do it for them. My grandmother had the dealer turn off hers in her 09 Camry. You can also physically remove the buzzer too, I don't think you should have to add anything to bridge the circuit once it's gone either. Your other option is to bypass the weight or seat belt switch in the seats so that they always read as being occupied and buckled in.
I haven't done this in a yaris before but I bypassed the seat switch in another car I had when I swapped seats, so now the seat always reads occupied and buckled in (also so the airbags will work)
Brighton is offline   Reply With Quote
Old 08-30-2019, 12:06 PM   #3
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Are you asking because you have aftermarket seats? Why is the chime going off?
On Instagram
On Wheelwell
Old 09-06-2019, 01:56 PM   #4
BIGTAZ351
147K-Blue / 24K-Yellow
BIGTAZ351's Avatar
Drives: 2010 Ylw 3dr. AT(Blue-Wife's)
there is a switch (therefore wires that can be connected/disconnected) in the female end of the seat belt....however passenger airbag won't work I know this because I use a seatbelt extender to shut up the passenger side... Lunchbox/cooler is heavy enough to make it beep!
All Weather Package, Power Package, Cruise, WeatherTech Floor Mats. Altimax Arctic Winter Tires.
Repair List:
1 new blower motor, making funny noise. @ 91K (Water pump @ 120K)
Mod List:
1. Black tape on most of the annoying blue high beam light behind the lens. (thank you CTScott)
BIGTAZ351 is offline   Reply With Quote
Old 09-06-2019, 03:04 PM   #5
myfirstyota
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped
I have removed the buzzers from both my yaris with no other issues. Its very simple actually. Grab a small screwdriver and gently pry the buzzer from the board while applying a soldering iron to the other side. Pops right out
You will however lose your headlight warning and other warnings that use the buzzer.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61427
Bolt-in 3.75" Suspension Lift Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61577
myfirstyota is offline   Reply With Quote
DIY - Replacing the Front Seat Cushions CTScott DIY / Maintenance / Service 6 10-04-2016 06:39 PM
seat belt chime disable? Lewis DIY / Maintenance / Service 19 05-25-2012 04:36 PM
Clazzio Seat Cover DIY Install PETERPOOP DIY / Maintenance / Service 31 09-10-2010 03:30 PM
I NEED to Figure a Way to Get More Front Seat Leg Room msmitka General Yaris / Vitz Discussion 25 09-08-2010 07:29 PM
Rostra seat heater and lumbar support sesmith In Car Entertainment + Electronics (audio / video / alarm) 1 01-03-2009 08:51 AM
