Old 09-29-2019, 09:46 PM   #1
groundskeeperwilly
Drives: 2006 Scion xA
Starts the Dies
Hoping someone can help me out here. I bought a 2006 for my son to use as a commuter. It ran fine when we bought it. It needed the usual maint items, so I put it up on jack-stands and replaced a bunch of stuff, including new coils (Denso) and NGK plugs (.032). Now when I go to start it, it fires right up, idles for a second and then dies. It will do this repeatedly but never stays running. I confirmed the fuel pump is running. I went to the local pick-and-pull and replaced every fuse and relay under the hood and dash. Still the same result. Each time it throws all 4 coil codes. I'm baffled. One thought I had....To get it on jack stands, I had to lift one side at a time quite a bit. Does this car have a roll-over switch that might be shutting down the coils?
groundskeeperwilly is offline   Reply With Quote
Old 09-30-2019, 04:02 AM   #2
toyotavios_11
Drives: Toyota Vios
yur coils and plugs may not compatible
toyotavios_11 is offline   Reply With Quote
Old 09-30-2019, 05:24 AM   #3
Dragonslayer182
Teal Squealer
Drives: 07 Yaris Sedan
Your spark plugs likely need to be set to .44 instead, if you have the 1.5l 1nz-fe engine.
Dragonslayer182 is offline   Reply With Quote
Old 09-30-2019, 08:28 AM   #4
Why did you replace the coils? Only reason to do so would have been if they'd been throwing codes in the first place. If your old coils and plugs haven't been tossed, put them all back in. Then start over by replacing the plugs, properly gapped.
Old 09-30-2019, 09:27 AM   #5
komichal
First of all I would put back the old spark plugs and coils.
You may need to erase the codes otherwise they will still appear.
If the engine runs with the old stuff smoothly, you can change the plugs. No need to replace coils if there is no error code with the old ones (or some "strange" engine behavior).
Make sure your plugs match the engine. The "European" 2SZ-FE likes BKR5EYA but you probably do not have this engine.
Old 09-30-2019, 12:40 PM   #6
groundskeeperwilly
I do have the 1.5l 1nz-fe engine. I'll try all that and report back. Thanks!
Engine shutting off at idle, dash lights flickering, and engine starts on it's own! jack.duno DIY / Maintenance / Service 0 09-23-2019 10:08 PM
Sometimes it starts and sometimes it doesn't Roetroc DIY / Maintenance / Service 3 08-15-2019 07:11 AM
2008 yaris starts then dies out in 10-15 seconds Kmartboy808 Hawaii 4 12-24-2018 04:14 AM
Car Dies While Driving josh044 DIY / Maintenance / Service 6 07-28-2017 11:07 PM
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 04:59 AM
