![]() ![]() Drives: Toyota Vios Join Date: Feb 2013
Rear deck ticking noise due to body flex
Owing Yaris sedan 07 model. Recently notice that there is ticking noise from rear deck whenever the car is over rough pavement. Initially thought that it was due to rattling of interior panels, so removed all the rear panels including seats and seatbelt mechanisms to diagnose the source of noise, but ticking is still there. Hide to the trunk to check the noise when someone is driving for me and notice that the rear seat striker panels which welded to the rear deck are making the noise due to body flex.
I try to "crack" the five spot weld points of each striker panel but useless and now im clueless to solve this. |
![]() ![]() ![]() Drives: 2007 Join Date: Feb 2014
If the seam is open you can try foam insulation (expanding) or caulk.
![]() ![]() ![]() Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
The Yaris is a pretty noisy car. You could try butile insulation like dynamat. It's this heavy tar like stuff that absorbs a lot of the vibrations and resonance that thin sheet metal in cars creates.
![]() - Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles UK to Nordkapp in a Yaris
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped Join Date: Feb 2016
Rattles and reliability. Yaris definitions.
No one suspects the Yaris. Xd/2zr-fe Swap/Build Thread http://www.yarisworld.com/forums/showthread.php?t=61427 Bolt-in 3.75" Suspension Lift Build Thread http://www.yarisworld.com/forums/showthread.php?t=61577 |
I'll take your word for it. I have no inentions of owning a ford anytime soon ha!
| Rear window sedan crackling noise. | krolos | General Yaris / Vitz Discussion | 3 | 04-09-2011 12:39 AM |
| Newly refreshed 2011 Toyota Corolla | Kal-El | Off-topic / Other Cars / Everything else Discussions | 23 | 11-27-2010 12:57 PM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 04:43 PM |
| Noise coming from rear end! | tfman716 | General Yaris / Vitz Discussion | 15 | 10-28-2008 12:37 PM |
