Old 04-24-2020, 08:53 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
At it again...Another Wheel Restoration
I've got to get control of myself. I picked up another set of Accent wheels with virtually new rubber. These wheels are in better shape than the set I just restored were in when I got them.
I have taken some of the advice offered by others. I plan to paint these a different color. I am heavily leaning toward black but not sure if I ought to go gloss black or satin; solid color or metallic. The other option is gunmetal grey, but it's less likely than the blacks.
The other decision I have to make now is if I will go full 2K paints or rattle can these ones. I know that I can get an excellent finish with acrylic enamel paint and clear coat spray cans. It would be a lot easier and much less work. The wheels would obviously never see winter and they will only be on the car part time. I've read many reviews of the Duplicolor products (many of which I've used) and apparently the wheel paint is very durable. I am however considering a single stage urethane - apparently the toughest finish, next to powder coat, I assume, and even tougher than basecoat/clearcoat.
Anyway, feel free to weigh in about color and finish (satin or gloss) if you feel so inclined.
Here are the new wheels:
Old 04-24-2020, 09:43 PM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
Well, you know what I think about black wheels; they just seem to disappear into the tyres (unless they have a silver rim) and do very little for most cars... unless you're going for the murdered out look.
Silver cars with dark bronze wheels look quite sexy IMHO.
How about this colour in matte or satin finish, perhaps with silver or black centre cap and lugs:
Old 04-24-2020, 10:36 PM   #3
06YarisRS
I must confess, Kimona, that that is a beautiful color. I am trying to envision that color against the Silver Streak Mica.
Edit: I found this... I hope I haven't violated any copyright by posting.
Bronze on silver
Old 04-25-2020, 01:07 AM   #4
Out of your color choices, I'd go gunmetal. Black wheels just don't look good to me.
Also, make sure you wear a respirator when using 2k paints.
And as a left field suggestion, what about a dark blue color?
Here's a silver S2000 with mag blue Volk CE28.
Silver G35.
Silver M3.
Old 04-25-2020, 01:51 PM   #5
06YarisRS
Yeah, still in the decision phase. I'm working on prepping the wheels now. And, yes, I have 3 NIOSH approved respirator 1/2 face masks. I cover up well and use latex gloves when spraying paints (isocyanates or not).
Thinking more about it, these wheels have very slender spokes and there is a lot of silver color behind my wheels - calipers, rotors etc. I think that in this situation, black might actually look good. The bronze and gunmetal are still contenders though.
Old 04-25-2020, 02:13 PM   #6
06YarisRS
UPDATED with new pics
Curb Rash Galore.
Honestly, I don't know how people curb their wheels so much! How do some people get their driver's license in the first place???
I hadn't noticed the extent of the curb rash when I bought the wheels. They were in a poorly-lit garage. Fortunately most of the rash was minor; not too deep.
I'll update with pics as I go.
Obviously, having the beads built up through aluminum welding and machining them down would be the best approach, but that's not in my budget for these wheels.
This, I'll call "Wheel 1". It had the worst curb rash. The basic process is to first sand to see how much rash can be removed from the primer, paint and clear coat. Then filing gets the rough shape back. The aluminum tends to squish out in all directions with impact and causes high spots on the bead and wheel lip that need to be filed down before filling. In the case of "wheel 1", a lot of aluminum was left on a curb somewhere, so it will need to be built out 1/16" - 1/8" to restore the arc of the wheel.
I've done lots of reading and JB Weld when primed, painted and clear coated can quite easily stand up to a tire changing machine.
Wheel 1
Wheel 2:
This may require another small thin application of JB Weld. BTW, this was sanded and filed down prior to applying the JB Weld, just no pic.
Other wheels with curb rash
Old 04-25-2020, 05:23 PM   #7
Satin
Old 04-25-2020, 08:07 PM   #8
06YarisRS
Satin
Thanks! If I don't go for satin in the end, Barber, know that I ended up doing this because it was you, I believe, that suggested a different color. So, your advice was heard and taken!
Old 04-25-2020, 07:45 PM   #9
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
I vote gunmetal grey. But not sure why I get a vote, it's your car.
NYC-SE is online now   Reply With Quote
Old 04-25-2020, 08:11 PM   #10
06YarisRS
Thanks! Haha, yeah, since I'm a wee bit indecisive by nature, I hoped for input. I do value peoples' opinions, but clearly will have to make my own decision. Maybe I'll surprise everyone with something more radical. Yeah....probably not.
Old 04-25-2020, 10:24 PM   #11
Steve35
Steve35's Avatar
Drives: 2008 HB
I like black. This is my "other" car.
Steve
Steve35 is offline   Reply With Quote
Old 04-25-2020, 11:43 PM   #12
06YarisRS
Steve
OOh, that's nice! Super nice turbo Miata. That is an intercooler in there, right? The black does really go well with the silver/grey! Haha, just noticed the car in the background. Also silver, with black wheels. This helps. Can't quite tell from the pic, but are yours gloss or satin finish?
Old 04-30-2020, 07:56 AM   #13
Steve35
Steve35's Avatar
Drives: 2008 HB
Turbo is right, its a 2004 Mazdaspeed Miata on one of two years Mazda turboed them. The color is Matt Black. I got them here.
https://www.good-win-racing.com/Mazd...t/61-2677.html
Steve
Old 04-30-2020, 09:59 PM   #14
06YarisRS
Steve
I had a look. Very nice wheels, indeed! Before I decided to save a few bucks and go with another set of Accent rims, I was looking at these.
https://www.canadawheels.ca/fast-whe...dvehicle=81922
And for a bit more...
https://www.canadawheels.ca/ultra-wh...dvehicle=81922
Old 04-28-2020, 06:52 PM   #15
06YarisRS
A color has been chosen. The wheels have been painted and are curing now. The 'reveal' will be in about 3 - 4 days.
Old 04-29-2020, 08:00 AM   #16
Leegamer
Leegamer's Avatar
Dang, JB weld works really well for covering that curb rash. I would have never thought of that.
I'm a hermit named Lee
Old 04-29-2020, 12:07 PM   #17
06YarisRS
Yeah, it's pretty tough stuff. It should stand up to a tire changing machine.
Old 04-29-2020, 07:14 PM   #18
Neinris
Drives: 08 Yaris 3 Door Hatchback
GOLD SPOKES!!!!!!!!!!!!!
Neinris is offline   Reply With Quote
DIY aftermarket steering wheel install with horn and airbag delete tmontague Performance Modifications 19 11-30-2018 12:19 PM
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 04:20 PM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
