![]() Drives: YARIS Join Date: May 2017
Replaced Rim
I recently had to replace one wheel due to bent rim. I forgot about the tire pressure sensor. I’m not that familiar with how that works. My question is how do I go about fixing this so that i can once again rely on the warning system?
For obvious reasons the tire pressure warning light is on. |
![]() ![]() ![]() Drives: 2015Yaris, Son's car, 10 Prius Join Date: May 2010
The sensors are the valve stem. You should of used the same valve stem and then it will be ok. Otherwise you will need to buy a new sensor and have a tire shop pair it to your system.
| Tags |
| tire pressure sensor |
| Is getting the rim repaired worth it? | nookandcrannycar | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 19 | 10-10-2014 04:22 AM |
| Rim 13" or 14" Yaris Hatchback 2008 | Bearmantle | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 04-19-2013 12:11 PM |
| tire noob question..what's the widest tire size can run on stock 15"s? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 12-06-2011 09:44 AM |
| I NEED A 15" STEEL RIM AND OEM TIRE | robkay | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 0 | 12-18-2009 10:57 AM |
| Rim sizing - what size to get for OE equivalent? | jay | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 11-20-2006 03:25 PM |
