Old 01-29-2021, 12:00 AM   #1
Tyguy81
Drives: 2007 sedan base model
Wider tire
Hello all. So I just bought some oz wheels 15x6. I want to go wider, I know there's some kind of formula to do that any help would be greatly appreciated thanks.
Tyguy81 is offline   Reply With Quote
Old 01-29-2021, 07:32 AM   #2
https://www.yarisworld.com/forums/showthread.php?t=5021
Old 01-29-2021, 09:25 AM   #3
Tyguy81
So any of the sizes on the chart will keep me close to overall diameter? Stock size is 165/60/15, I can do the 205/50/15 and it'll be close?
Old 01-29-2021, 10:20 AM   #4
Neinris
Drives: 08 Yaris 3 Door Hatchback
I hope that's a typo... Stock tires are said to be 175/65R14 or 185/60/R15. I'm on 185/60/R15 and I notice that my speedometer is inaccurate. I'm actually 2MPH over than what my speedo is reading. So I think my speedo ring and pinion is set for the 175/65/R14. And it coincides with the calculator that's mentioned in the post above. But here it is anyway: http://www.rimsntires.com/specspro.jsp
You'll see that 205/50/R15s are the closest perfect match to 175/65/R14s.
Neinris is offline   Reply With Quote
Old 01-29-2021, 08:44 PM   #5
Tyguy81
Thanks to both of you. I have the 185 65 15 steel wheels and tires on it right now.
Old 01-29-2021, 09:17 PM   #6
Tyguy81
So according to the chart 215 55 15 tires would be the closest to the same diameter as the stock 185 65 15. Will the wider tire work on a 15x6 wheel.
Old 01-30-2021, 07:59 PM   #7
kimona
kimona's Avatar
Drives: 2014 White VITZ
^^^ 205/55/15's (23.9") are closest to stock 185/60/15's (23.7") in diameter... and work very well on stock suspension and 6" rims.
Use of a can of tire sealant voided road hazard warranty nookandcrannycar Wheels, Tires and Suspension Forum sponsored by The Tire Rack 24 02-22-2014 07:49 PM
NITROGEN GAS TIRE FILL: WORTH IT? EjDaPogi Middle East 15 03-20-2011 02:06 AM
Tire rotation: Does TPMS recognize tire position? jcdrotos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-17-2011 02:00 PM
Tire Size and FE question GMKing Fuel Economy Forum 8 09-01-2009 09:20 PM
