Old 02-27-2021, 02:00 PM   #1
ollie.send
Drives: 2007 Toyota Yaris MK2 1.33
2ZR-FE Swapping My 2007 Yaris MK2
Hi Guys!
I was looking to swap my current 2SZ-FE (1.33) for the 2ZR-FE (1.8). I know there’s a thread for this swap already but I was hoping someone would know the answer to the question I’m about to ask.
If I bought a complete say Corolla for example from Copart with body damage for example. If I swapped everything I needed from the Corolla into the Yaris would I run into any issues?
Cheers
Ollie
ollie.send is offline   Reply With Quote
Old 02-28-2021, 11:05 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by ollie.send View Post
Hi Guys!
Cheers
Ollie
I didn't know there was a thread that addressed specifically going from a 1.3 to the 2zr. I think you'd need to look at wiring diagrams. Also, you would need a passenger side engine bracket and mount from a Scion xD. Afaik, the Corolla engine and transmission won't directly mount in the Yaris engine bay. I'll be following if you go ahead with this project. Cheers.
2sz-fe, 2zr-fe, swap, yaris
