![]() Drives: 2014 Toyota Yaris (manual) Join Date: May 2021
2014 Toyota Yaris manual
Hello. I have a 2014 Toyota Yaris (manual) and I would like to install cruise control but I have no idea how to.
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
See This thread. It has all the information.
https://www.yarisworld.com/forums/sh...ad.php?t=37205 You will need the cruise control switch and clutch switch.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
![]() Drives: Yaris hb 2012 Join Date: Oct 2021
Did you install it? It was hard or it was not that hard? I have a 2012 manual one
![]() ![]() Drives: 2009 Yaris 2dr Liftback Join Date: May 2019
if you have the steering wheel with radio controls, there is a pop out panel in the side of the wheel that the switch lever goes through. There is also a socket for the switch wiring to plug in.
The wiring for the clutch switch is most likely taped up, so you will need to cut some electrical tape away to get to the connectors. Without the clutch switch, the cruise control will not work on a manual transmission. The switch disconnects cruise control when you push the pedal, so the engine revs don't shoot up. I have an automatic, so only had to fit the switch. it took longer to figure out how to get the airbag/ horn assembly off than to install the switch.
| Tags |
| cruise control |
| Toyota Yaris manual | Mishu47 | General Yaris / Vitz Discussion | 0 | 05-20-2016 05:13 AM |
| 2008 Toyota Yaris 55k miles 47+MPG HWY 5-speed manual - $8300- MIDWEST/INDY | alch3miss | Cars for Sale by private party | 0 | 03-18-2015 01:20 AM |
| GT5 Gran Turismo 5 | Bluevitz-rs | Off-topic / Other Cars / Everything else Discussions | 144 | 03-04-2011 10:13 PM |
| 2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 05:54 PM |
