Old 06-08-2021, 10:55 PM   #1
LH123
Drives: 06 Yaris RS
OCS Bypass / SRS Light
I recently purchased a second-hand Occupant Classification Sensor Bypass Module (Rev. 2.0.0). After the installation of the module, the dash airbag light came on.
I tried the DTC code clearing procedure described in this post: https://www.yarisworld.com/forums/sh...d=1#post557473. When I turn the ignition on, the SRS light comes on solid the P/S and ABS light flash at about 5 flashes/second. Any ideas on how to clear the error codes?
Vehicle is 2006 RS 2-door hatchback, Canadian.
LH123 is offline   Reply With Quote
Old 06-09-2021, 11:08 AM   #2
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Are you certain you moved all driver seat sensors over? I got tripped up by one that has a magnet to it, which I had to stick to the seat bracket.
On Instagram
On Wheelwell
Old 06-09-2021, 03:44 PM   #3
LH123
Drives: 06 Yaris RS
I only removed the passenger's seat - the driver's seat is stock.
Old 06-09-2021, 04:47 PM   #4
ern-diz
ern-diz's Avatar
Hmm...have you triple-checked that all connections are tight? You moved the seat belt pieces over, too, right?
On Instagram
On Wheelwell
Old 06-09-2021, 08:02 PM   #5
LH123
Drives: 06 Yaris RS
I am using the bypass module shown in this document: https://www.metaltech4x4.com/content...n%20Rev2.0.pdf. I completed step 1, skipped the optional step 2, and am having trouble clearing the fault codes as described in step 3. Step 4 will not be necessary as my seats do not contain side airbags. All connectors are seated correctly.
Old 06-09-2021, 10:49 PM   #6
LH123
Drives: 06 Yaris RS
Turns out you were correct. I didn't think that the seat belt connector had to be connected to keep the system happy. When I hooked that up, the fault cleared. Thanks for your help!
Old 06-10-2021, 10:30 AM   #7
ern-diz
ern-diz's Avatar
Yes, the seat belts are part of the overall SRS system. My pleasure, glad you got it sorted :)
On Instagram
On Wheelwell
I finally cracked the Odometer and SRS ECU code CTScott DIY / Maintenance / Service 22 10-27-2016 01:50 AM
Do your side windows wipe clear? CoryM DIY / Maintenance / Service 6 10-29-2013 11:50 PM
P1345 Error code Nicholas2003 DIY / Maintenance / Service 0 02-03-2013 06:47 AM
Error DTC B1901-B1906 how repair?? Carlosk1 DIY / Maintenance / Service 2 08-30-2010 05:15 PM
Error DTC B1901-B1906 Carlosk1 Central and South America 0 08-29-2010 09:48 PM
