Old 09-22-2021, 07:30 PM   #1
Bluebaby
Drives: 2007 3 door
Lower motor mount/torque strut/"rod, engine moving" replacement...what am I in for?
I have a '07 5 speed hatchback with a bad lower motor mount (part pictured). The part came in today, and I want to know what I'm in for. I can't seem to find any guides online or info in the service manual.
Is changing this part a simple case of undoing two bolts and tightening two bolts, or is it something where I need to jack up the motor, undo the other mounts, etc etc...any advice/tips would be appreciated here.
Bluebaby is offline   Reply With Quote
Old 09-22-2021, 08:10 PM   #2
ex-x-fire
Usually you'll need a floor jack to rock the engine slightly to line up the bolt holes. Looks like it goes into the cross member, it should slide right out. I'd say a half hour job, more then an hour, your goofing off.
Old 09-22-2021, 08:52 PM   #3
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
The vertical bolt can only be accessed from above the subframe, can't recall if there's enough clearance to remove it without significant disassembly...
Old 09-24-2021, 08:24 AM   #4
ex-x-fire
Calls for 0.8 hour book time in AllData, so it can't be too bad. It didn't show any procedures though.
Old 09-26-2021, 08:42 PM   #5
Bluebaby
Drives: 2007 3 door
Awesome, thanks for the info all! It looks like there's enough room above the subframe to get it out without too much difficulty, so I'm giving it a go tomorrow afternoon
engine, motor, mount, transmission
The Nitrous Thread ChinoCharles Performance Modifications 116 02-16-2016 04:07 PM
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 06:34 AM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 05:22 AM
Lower Grill Replacement Idea (feeler) counterfiend Cosmetic Modifications (Exterior/Interior) 7 09-24-2009 09:40 PM
The last gas question Tonavi DIY / Maintenance / Service 56 04-27-2009 09:40 PM
