Old 09-27-2021, 06:18 AM   #1
ReiZeMuitoGordo
Drives: Toyota Yaris
Exclamation Speedometer does not turn off
Hi, First post here :)
Well I have a Toyota Yaris and when I remove the ignition key its speedometer (digital) doesn't turn off and it's always drawing current from the battery.
I disassembled the speedometer and tested it on the bench and when I disconnect the key wire the current is at 17mA and it doesn't turn off.
Does anyone have any solutions?
lengths,
ReiZeMuitoGordo
ReiZeMuitoGordo is offline   Reply With Quote
Old 09-27-2021, 12:22 PM   #2
bronsin
bronsin's Avatar
How many amps does the speedo draw?
Old 09-27-2021, 02:05 PM   #3
ReiZeMuitoGordo
I think it's normal when everything is working it should be between 200 mA to 150 mA but as you can see from the images when it's on it's 180 mA and when the ignition is off it continues with 170mA and it should go to 0 after 1/2 seconds.
Old 09-30-2021, 08:00 AM   #4
bronsin
bronsin's Avatar
It possible to put an on off switch in the wire going to the speedo?
I had a motorcycle with an electric fan that would overheat in city Traffic but was fine on the highway. So I put it on off switch to turn the fan on as soon as I got in traffic.
Bingo no more overheating!
speedometer problem
Using turn indicators as DRLs on 2009 HB tamrat In Car Entertainment + Electronics (audio / video / alarm) 26 09-11-2023 12:45 AM
Projectors retrofit, black reflectors and dimmed front turn signals my2sense General Yaris / Vitz Discussion 11 06-20-2012 11:39 AM
Will local bay area members please stand up! YarisSedan California 264 07-28-2009 11:53 PM
