![]() Drives: 2008 Toyota Yaris Hatch Join Date: Feb 2021
replacing radiator, 2 small hose fittings on bottom of new radiator
I have 2008 yaris manual transmission. I hit a block of ice today and now coolant is coming out of the front end. I got a new radiator and it has the upper and lower hose connections, and it also has 2 brass fittings on the bottom that stick out towards the engine. I dont see those on my existing car. I am assuming those are for a transmission cooler for an automatic? I have a manual. Can I just cap off those fittings? I would assume those are also a separate "passageway" than the coolant, designed for the ATF fluid to flow through the radiator in its own channels. So technically you can leave them completely open. Correct?
![]() ![]() Drives: 1983 carina 2NZ-FTE Join Date: Dec 2020
yes
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Need advise (Radiator Hose/ Thermostat Gasket) | vellano | DIY / Maintenance / Service | 7 | 12-12-2012 11:37 PM |
| Silicone radiator hose | VA_yaris | General Yaris / Vitz Discussion | 18 | 07-31-2011 04:13 PM |
| Radiator hose size | window_lee | General Yaris / Vitz Discussion | 0 | 03-31-2009 06:33 AM |
| Radiator Hose Question | Treyz | General Yaris / Vitz Discussion | 6 | 11-16-2008 06:56 PM |
