Old 06-11-2007, 07:15 PM   #1
The Stig
The Stig's Avatar
Drives: 07 LB MM 5spd, 99 M Coupe
n00b suspension install question
If I'm going to install Tein S Springs + TRD Shocks, do I need (aside from tools listed in DIY sticky):
1, Spring compressor?
2, Reuse stock bump stop?
3, What else do I need?
Thanks in advance guys!
The Stig is offline   Reply With Quote
Old 06-11-2007, 09:33 PM   #2
nqd
Drives: 07 Yaris LB Absolute RED
i installed my s techs with the same bump stops but i used the stock shocks.... and yes you will need a spring compressor for the stock spring... i bought a set from my local automotive store and returned it the next day....
and third some beers and a nice sunny day
nqd is offline   Reply With Quote
Old 06-11-2007, 09:59 PM   #3
joey1320
joey1320's Avatar
Drives: Yaris LB
add a good pizza and some sweaty hot chicks to pass you the tools.
but besides that you will need a spring compressor to switch over the top mount plates. you can either rent them or buy/return it if you don't plan on using it again.
joey1320 is offline   Reply With Quote
Old 06-11-2007, 11:26 PM   #4
when we installed mine (same set up), we didn't need to use spring compressors. and we cut the bump stop like how Chris did.
heh, get ready for a stiff ride (although i wish it is a tad bit stiffer).
Old 06-13-2007, 01:37 PM   #5
The Stig
The Stig's Avatar
cool, all i need now is about 50 hot chicks to pass me tools
thanks guys!
Old 06-13-2007, 02:44 PM   #6
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
im also getting ready this saturday to install the same setup. CHRIS or someone else can you tell me how much you cut your bumpstops and do i really need to if i use the stock struts.....
Old 06-13-2007, 03:41 PM   #7
Toyotech
Your Toyota Technician
Drives: 06 Cobalt SS/SC, 06 Rolla S
Send a message via AIM to Toyotech
normally cut about 2 ribs off
Toyotech is offline   Reply With Quote
Old 06-13-2007, 04:12 PM   #8
ROCKLAND TOYOTA
TRIM HUNTER
THIS IS GOOD FOR BOTH THE TRD AND STOCK STRUTS????
Old 06-13-2007, 07:18 PM   #9
churp
Clean and (dis)Functional
churp's Avatar
Myself I wouldn't cut them for the stock struts...they are designed to keep the strut cylinder from bottoming out. The bump stop bottoming is much softer and less damaging that having the cylinder bottom out. Aftermarket struts are probably different, but I can't imagine any car manufacturer engineering their products with more clearance than needed....it usually costs money!
Has anyone actually checked how far down the strut can go, with and without the bump stops....would be easy to do with the spring off. Then you could tell how much distance the bump stop has to compress before the cylinder bottoms. Of course then you'd have to decide how much you think the bump stop would compress under a severe load. No matter what...the longer the bump stop is the softer the 'thump' will be when it hits.
____________
Old School Cobble Jockey
Old 06-13-2007, 03:49 PM   #10
death is my gift
wacky broadway nightmare
death is my gift's Avatar
Drives: Willow is a '07 Red Yaris LB
Send a message via AIM to death is my gift Send a message via MSN to death is my gift Send a message via Yahoo to death is my gift
stupid boys with your tools.
i STILL haven't gotten my Yari lowered.
good luck Stig
"it's always complicated and at some point someone has to draw the line and that is always going to be me. you get down on me for cutting myself off but in the end the slayer is always cut off" Buffy
death is my gift is offline   Reply With Quote
Old 06-13-2007, 03:51 PM   #11
kurokoma-kun
Drives: 2007 Yaris HB
good luck Stig
Maybe he will do it for you if you pass him the tools?
Seriously I have a question about the spring compressor... is it completely safe to use at home? Something about handling the spring while its tensioned freaks me out...
my yaris, kurokoma-kun
Old 06-13-2007, 04:35 PM   #12
The Stig
The Stig's Avatar
yeah i'm kind of paranoid about the compressor too, but i guess it's ok....it ain't my garage LOL...
death: i'm mechanically challenged...however, i got some mad lego skillz...reading a couple of DIYs got me think that this is just a full size lego set....yeah, i need lots of luck here
Old 06-13-2007, 09:57 PM   #13
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
or some huge guy named Hans to compress the spring for you
Old 07-11-2007, 12:20 AM   #14
Jerkratt
Jerkratt's Avatar
my friend put spings in his mazda prog... and they used 4 ppl holding the spring down lol in his front lawn
"It hurts more when its wet"
Old 07-11-2007, 02:21 AM   #15
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
Usually however far you drop it say its an inch then you cut an inch off the bump stop. I believe that is the rule of thumb. Double check Chris's DIY for sure.
Old 07-11-2007, 08:01 AM   #16
MrJester
Drives: homo
I cut ribs down on the bump stop don't notice much rub at all. There a couple pot holes on my way to work that will bottom me out but they are quite large so I just do my best avoid them. :)
MrJester is offline   Reply With Quote
Old 07-11-2007, 10:32 AM   #17
nqd
yes i beleive its the same set up as the xb
Old 07-11-2007, 02:42 PM   #18
i didn't need a spring compressor when we installed my S.Tech's.
Finishing my suspension ChinoCharles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-15-2011 09:26 PM
question about radio install misfits9095 In Car Entertainment + Electronics (audio / video / alarm) 8 06-06-2007 03:08 PM
NorCal: Suspension install The Stig California 12 06-05-2007 12:51 AM
Suspension Setup Question Ran Kizama Wheels, Tires and Suspension Forum sponsored by The Tire Rack 27 04-28-2007 02:05 PM
n00b question... djfuji Cosmetic Modifications (Exterior/Interior) 9 01-29-2007 10:47 PM
