![]() Drives: 08 Yaris 3dr Join Date: Oct 2018
I recently replaced the clutch for my Yaris. Along with the flywheel and pressure plate. Before I started bolting more things back together I figured I should test to make sure that neutral was neutral, and discovered what is seen in the video.
https://youtube.com/shorts/LyJIz_jwhSs At 8 seconds I press the clutch pedal in. At 13 seconds I release the pedal. I am 95% sure this means I need to take the transmission out again, but I would like someone more knowledgeable than I am, cause I'm sure not, to weigh in. |
No, that's normal when the tranny fluid is cold. For some reason the spinning main shaft cause the fluid to whip up and make the other shaft turn a bit. Put the wheels on and you'll see that you can stop it easily by hand.
Thank you ex-x-fire. I did notice that it was easy to stop by hand when I had a tire on.
remcafee - I did not install a lightened flywheel. I put an OE flywheel in. I know I have come across old posts about lightened flywheels on the forum though. |
![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
did you install a lightened flywheel? im thinking about doing one and trying to seenif anyone here had one so i can get some input
If it's a daily driver I wouldn't use a light flywheel.
| About to replace the transmission fluid on an automatic 2008 yaris with 172kms | jessesYaris | General Yaris / Vitz Discussion | 6 | 09-23-2021 04:51 PM |
| Transmission heating up ? | David C | DIY / Maintenance / Service | 9 | 08-04-2016 01:25 PM |
| Transmission oil? | jamesxl | DIY / Maintenance / Service | 3 | 04-11-2016 10:18 PM |
| Problem help | MickZEL | DIY / Maintenance / Service | 38 | 08-01-2011 02:52 PM |
