Old 06-01-2022, 09:53 PM   #1
TommyWasabi
Drives: 07 AT & 08 MT Yaris HB 3dr
2007 Vitz JDM folding mirrors
Does anyone have any experience installing JDM side folding mirrors? I did a search and could not find anything useful.
I was mostly looking for wiring instructions. My 2007 Yaris LB has the manual windows so no power anything. Before I purchase I just want to make sure I can even get them to work. Thanks in advance!
TommyWasabi is offline   Reply With Quote
Old 06-03-2022, 02:03 PM   #2
sh0rtlife
pop the kick panel and have a look to see if you have the power hookup at all, if not youl be in for a bit o wiring shold be a bulkhead back there that makes everything plug n play..some have it.......some dont
Old 06-05-2022, 03:56 PM   #3
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
Unless the gen 2s are all pre-wired for power mirrors like the gen 3s are, I hope you like wiring. lol
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 06-05-2022, 06:24 PM   #4
It's too bad the MicroImage site went tits up. We had a member in Guelph who did it to his 2010. There had been an excellent write-up on the project. It was a significant challenge is all I can remember.
Old 06-06-2022, 01:26 AM   #5
sh0rtlife
let me preface this by saying i have no idea what those mirrors are or how they are wired
with that said
i have added power mirrors, door locks and even power windows to cars that never came with them and were never wired for them
the biggest issue with mirrors(and this is a generalization) is that you need to have a semi matching switch...IE if its a 5 wire setup then you need a 5 wire switch...ive seen some weird units where they have mmulti pole motors and alot more wiring involved
your typical mirror works in 2 motor setup 4 wires in total there is no "ground" the switch is your ground and you run all 4 wires from the motor back to the switch, and you power and ground the switch and then draw power from a fuse and chassis the ground...teh switch itself powers one wire and grounds the matching wire, this can all be figured out in short order with a multi meter
so long as your comfortable running wires its not useualy a big deal
worst one i ever did was power windows into an 86 civic from an accord....that was a brutal one..the holes in the doors wernt even the same
Old 08-06-2022, 11:07 AM   #6
TommyWasabi
To give you all an idea of what I am talking about.
Old 08-07-2022, 12:43 PM   #7
sh0rtlife
if you pop off the painted cover to expose the wiring at the individual parts figureing it out should be a breeze
is the light a single turn signal or is it a combo marker/signal?
Old 08-16-2022, 09:38 AM   #8
TommyWasabi
Good question, I know they are signal, but not sure about marker. I'd have to do some digging. From a cursory look, they were only released to the Asian market, most of these I've seen have come out of Thailand.
Old 08-08-2022, 10:39 AM   #9
mannycheckers
Drives: 2009 Yaris 2dr Liftback
I don't have experience with the JDM power folding mirrors. However, I can confirm that adding replica power mirrors to a USDM 2009 yaris is as simple as buying mirrors *with the motor pre-installed* and an OEM power mirror switch and installing them. My car was pre-wired between the mirrors and the switch which is located under the driver side AC vent.
*EDIT*
mannycheckers is offline   Reply With Quote
Old 08-16-2022, 09:39 AM   #10
TommyWasabi
*EDIT*
I'll need to check to see if my Yaris is pre-wired. Keep in mind I haven't bought them yet, the pics above are from the sales listing.
Old 09-01-2024, 09:34 PM   #11
Harkane
Harkane's Avatar
Drives: 2007 Yaris YRS hatchback
Did you ever end up giving this a go? I'm looking at doing the same with my 07 Yaris hatch, it has powered mirrors for adjusting but I want the power folding.
Harkane is offline   Reply With Quote
Old 12-03-2024, 01:24 PM   #12
TommyWasabi
I didn't. I'm in the process of setting up my garage and haven't gotten around to it. If I decide to try it, I'll post about it.
JDM folding mirrors with signals............ 3cyltrbo Cosmetic Modifications (Exterior/Interior) 22 08-01-2016 06:34 AM
FS: JDM Vitz RS Front (2009) and Rear (2007) Bumper (AZ and Possibly So Cal) jmew0ng Items for Sale by private party 23 10-05-2013 12:24 AM
WTB: JDM Power folding mirrors BlazingBlue08HatchBack Items for Sale by private party 0 04-10-2007 05:31 PM
