![]() ![]() Drives: . Join Date: Mar 2019
Electric to Manual window conversion?
Not an urgent problem, but I'm asking for future reference.
Is a conversion for power windows to manual crank windows on a 2011 2 door Yaris possible? |
Yes it is ...Google how to convert power windows to manual crank type.
BTW, I got my '09 Yaris as it was exactly what I wanted on the lot. It has the right color, a manual transmission with crank windows It also does not have a battery operated key fob.... One plain key operates everything. The more manual things you have, the less things that can break down. Also, at my age I have a driving life time of cranking car windows. :) |
on an 11 your challange is going to be finding the parts...like the door panel blanks...i figure the main panel more than likely has the spot marked to be "punched" out for the crank itself
im haveing the reverse issue..trying to find the power windows parts for an 07...5dr.....3dr stuff is easy to find..5dr not so much ..if it were a 3dr id leave it cranks..but those back side windows are hell to crank down while moving |
| The auto trans > manual trans conversion guide | ArmstrongRacing | Performance Modifications | 43 | 10-23-2022 03:33 PM |
| 07' Yaris Sedan, Driver Door, manual window crank removal | silverbullet17 | General Yaris / Vitz Discussion | 2 | 07-29-2016 03:32 PM |
| Electronic Window Closer mod | cali yaris | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 11-11-2011 11:16 AM |
| Help: Rear Door Small Window Install | nick.dollimount | DIY / Maintenance / Service | 7 | 09-22-2010 02:22 PM |
| HELP! Removing manual window crank | Astroman | DIY / Maintenance / Service | 8 | 05-26-2009 08:46 PM |
