Old 03-24-2023, 12:45 PM   #1
Griffin6218
Drives: 2004 1.0 yaris
Front brake back plate
Hi,
2004 1.0
Front brake back plates rusted away.
It looks like the hub has to come off to replace.
Am I right ?
Griffin6218 is offline   Reply With Quote
Old 03-24-2023, 03:00 PM   #2
That is correct, and the process will destroy your wheel bearing. Best just to run without a shield and replace it should the day come when your bearing needs to be done.
Old 03-24-2023, 07:21 PM   #3
sh0rtlife
as ive managed it with other cars..can you cut a section out of it to slip it in without pulling the bearings?...or is there no access to the bolts?....i know i did it on a 96 supra
Old 03-25-2023, 01:15 PM   #4
remcafee
you can ghetto rig something up, i tried doing that and kinda ruined my knuckle in the process, in the end you should do it right the first time and preparefor a new wheel bearing.
Problem removing front brake rotor jkuchta DIY / Maintenance / Service 24 02-27-2016 09:41 PM
MI SSK In-Cabin DIY (Golddeenoh) BEEF DIY / Maintenance / Service 5 03-26-2013 01:19 PM
2012 Nissan Versa Kal-El Off-topic / Other Cars / Everything else Discussions 22 06-15-2012 04:48 PM
new front brake pads yaris9876 DIY / Maintenance / Service 0 10-03-2011 09:12 PM
WTB: Front License Plate Mount and OEM wheels/tires Snarf77 Willing to Buy by private party 3 07-23-2009 12:43 PM
