Old 02-18-2024, 12:47 PM   #1
peter.danan1@yahoo.ie
Drives: Toyota yaris
Water leak in the boot,Yaris/Vitz II
Attachment 62809There appears to be a leak in the trunk of my Toyota Yaris II, specifically in the right rear corner. I suspect it might be coming from the area around the right rear light, where moisture also accumulates. Could this be due to an improperly installed seal picture no.1, or do I need to replace the entire rear light seal picture no. 2 ?
peter.danan1@yahoo.ie is offline   Reply With Quote
Old 02-19-2024, 01:13 PM   #2
lani100
lani100's Avatar
Drives: Yaris T sport TRD turbo
Taillight gaskets are prone to fail, remove the taillight and clean everything.
Check the condition of the gasket, ideally replace.
If you are cheap you can also use bathroom sealant
2004 Yaris T-Sport
1NZ-FE with TRD Turbo
lani100 is offline   Reply With Quote
Old 03-29-2024, 08:57 PM   #3
IndestructibleYaris
Use powder to determine where leak is coming from.and spray with a hose
IndestructibleYaris is offline   Reply With Quote
2008 toyota yaris 2 door hatchback water leak knobby bobby DIY / Maintenance / Service 8 07-03-2024 06:42 AM
Water Leak in Boot zoidberg444 DIY / Maintenance / Service 8 11-02-2023 12:34 PM
Advice about leak, water in spare tire well RMcG DIY / Maintenance / Service 20 01-29-2021 03:47 PM
09 Yaris Rear Water (rain) Leak Loki452 DIY / Maintenance / Service 14 03-02-2019 07:35 PM
08 Yaris water leak troubleshooting help requested 2bz DIY / Maintenance / Service 5 12-22-2018 05:37 PM
