Drives: Yaris T-Sport '01 Join Date: May 2015
Crank no start 01 Yaris Ts
Hi all, been a while but hoping someone can help me dive into this issue.
Couple years back had a minor incident with a crash barrier that mangled my hood and radiator support. Chassis is fine and found replacements for the rest. While I had the space in the engine room I swapped the engine (1nz-fe) as mine was using buckets of oil. After swapping engines gave the replacement a small service with oil, filter and plugs but engine ran very rough. Misfiring on cil 1. Switched coils from previous good running engine but problem remained. Have a bluetooth obd scanner but didn’t get any codes or useful information so tried my luck with a vci plug. Never got it to work, but now some weird issues remain.(yes, lesson learned on copies) - The cluster no longer displays the mileage unless the vci plug is in place - Engine cranks fine but wont run at all anymore… - After cranking the needles start dancing, only stopping after removing key - key “on” position doesn’t show cel So with the vci plug in place all looks fine, starts still but wont fire anyway. Things I’ve tried: - spray some brakecleaner to see if it runs, no luck - checked all fuses, efi, am2, etc all good - Have another Yaris, same year, engine etc and switched over ecu, key and cluster and was running fine so those components are good, thankfully ecu not fried I’d say maybe I fried the obd port or something, but how does one check that? Cant seem to find wiring or pinout info for this ecu (Fujitsu 89661-52230 mt) |
I suppose the "new" engine came from a reliable source and was working just fine in the previous car. Using engine from some totaled car would be unwise.
I am just thinking if we need to locate a problem caused by engine swapping or if we can consider the swapping done fine and it is all about a problem that came inside the "new" engine. |
| yaris won't start, engine truns over but won't start. | zara616 | General Yaris / Vitz Discussion | 16 | 09-05-2021 11:39 AM |
| 2018 Yaris SE 5MT - T-Sport w/Valvematic! | atomic_hoji | Performance Modifications | 130 | 02-23-2019 11:56 AM |
| Yaris Wont Start | magnum555 | DIY / Maintenance / Service | 0 | 10-29-2017 05:30 AM |
| 09 Yaris No Start | dieselphreak | DIY / Maintenance / Service | 47 | 03-16-2015 11:36 AM |
