Old 11-22-2024, 06:06 PM   #1
Norswede
Drives: 2007 Yaris hatchback
TROUBLESHOOTING FRONT TIRE VIBRATION
TROUBLESHOOTING:
Hey all, my '07 Yaris hatchback has 170,000 miles on it and is in pretty good shape. I have babied it with regular oil changes and taken care of basic maintenance as it arises. People are routinely shocked when I tell em how old my car is when they see it. 😀
However, we have an issue brewing that I need some help troubleshooting. Back in the summer of '23 we noticed during a vacation trip that there was a shake in the steering wheel (seemingly coming from the wheels/tires) at high rates of speed (60 mph+). If you drape your hand on the steering wheel, the shaking telegraphs thru the steering wheel and your hand looks like it has a mild Parkinsons type tremor.
We were thinking it was bearings and took it into our local mechanic who drove the car on the freeway with hubby in the car. He says it's not the bearings because there's no failed bearing noise and that if it were the bearings he and hubby wouldn't have been able to talk it would be so loud.
He suggested it could be the tires which makes sense--they were VERY old. So we swapped out the old tires for snow tires and the shaking is much improved but not entirely gone; I noticed it a bit on the freeway today. It just feels like there's a vibration coming from the front wheel area and--I hope this will be a HUGE clue for those in the know--the shaking and a non-bearing noise grew MUCH more noticeable when I was navigating a curve at between 30-40 mph and then all but disappeared again on a straightaway.
Please help!
Norswede is offline   Reply With Quote
Old 11-23-2024, 12:39 AM   #2
bairjo
Get the tires balanced.
Old 11-23-2024, 08:14 AM   #3
ex-x-fire
It's probably an axle shaft. When you turn one side plunges at the inner joint. Sometimes they just start binding up. Get the car up it the air, put it in gear and get the wheels turning. Apply the brakes a bit but keep the wheels turning. If its an axle you should feel it and a really bad one will move the engine/trans side to side a bit.
Mystery(misery?) vibration, I am determined to find a solution. seatech30 DIY / Maintenance / Service 4 06-16-2019 06:48 PM
DIY yaris III fog lights installation karloslatynos Third Gen Yaris General Discussion 53 11-12-2017 03:03 PM
My HS build CoryM Tracking, Racing, Auto-X Forum 26 05-14-2016 01:50 PM
Use of a can of tire sealant voided road hazard warranty nookandcrannycar Wheels, Tires and Suspension Forum sponsored by The Tire Rack 24 02-22-2014 07:49 PM
