Old 08-29-2025, 04:33 PM   #1
darionapa1
Drives: toyota yaris
yaris problem with accelerate, no work throttle
Is 2009 yaris diesel. Nlp90 model. On photo there is a faults and live screenshot after press accel pedal. Cant find the issue. First i had to power on the ecu to work. I cant find any relay or fuse for ecu. Is bosh 17cp07. The car start, all works exept accelerate, vin nbr; VNKKC96390A234466 MODEL NLP90R-CHFGXW ENGINE 1NDTV, AND CANT FIND WHWRE IS LOCATED ECM/PCM POWER RELAY CONTROLER. pls help so basicaly the ecu is not power on corectly, cant find the fuse and relay, i connected by wire from fuses, so not sure if is not missing some power wire to ecu give problrm to trotthle body. just if any one have same car can is possible to check where is 12v on ecu wireing after acc on . the car is start, u can drive just with the idle rpm. no reaction after press pedal.
darionapa1 is offline   Reply With Quote
yaris 2009, yaris diesel
problem with co-worker yaris, need opinion on what it could be. Adriaan DIY / Maintenance / Service 5 10-20-2014 06:39 AM
Yaris Central Locking Problem pbasuita UK 0 07-10-2010 03:46 AM
