Old 08-08-2007, 09:14 PM   #1
ttufrosty
Side Turning Signal
Curious if anyone else has had this problem.
I was waxing my car the other day, when my hand brushed the side turning light on the front quarter panel and the light popped off. Upon examination the plastic clip that holds it together was cracked and about to fall apart.
I am going to be taking it to the dealership in the next few days to get it replaced. Thankfully I am still under warranty.
ttufrosty is offline   Reply With Quote
Old 08-09-2007, 02:24 AM   #2
d2dailly
Roar?
Drives: 07 White LB Yaris
Send a message via AIM to d2dailly
um sorry but thats not covered under warranty... guarantee they are gonna charge you
d2dailly is offline   Reply With Quote
Old 08-09-2007, 06:19 AM   #3
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
yeah seeing as i have to use a screwdriver sometimes to take mine out. you must be wax offing a little too hard.....
Old 08-09-2007, 07:42 AM   #4
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
One of mine broke off already... I'd never even gotten the chance to take it off and on. The first guy at the dealership accused me of dicking around with it and breaking it, so I talked to the manager, and showed him the broken plastic clip, and they covered it under warranty. Cost would've only been like $22 CDN otherwise.
2006 Red Blitzed RS 5-door
Old 08-09-2007, 09:17 AM   #5
kimona
kimona's Avatar
Drives: 2014 White VITZ
Unless you played with it and broke it off in the process, it is definitely covered under warranty.
Old 08-09-2007, 07:27 PM   #6
ttufrosty
Nope just moving a towel over it, I will be extra gentle with it in the future. At least I am not the only one afflicted with this.
Old 08-09-2007, 11:07 PM   #7
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
here is something for you to notice on our cars...all the black/plastic trim pieces, when you get a chance, go out and touch them...kinda push on them or move them side to side...you don't even have to force it just lightly shift the piece...this is the first car i've owned where trim and panels and the such are snugged down but still have play in them....no matter what you do...unless you get the insulation foam and stuff it up in the crevices....
Old 08-11-2007, 08:57 AM   #8
ROCKLAND TOYOTA
TRIM HUNTER
most of the pieces i took off to pAINT was a couple of clips and some shitty double sided tape.....
Old 08-11-2007, 01:02 PM   #9
Meteorite Man
Passin' The Gas...Station
Meteorite Man's Avatar
Drives: Same As You But Different
Send a message via Yahoo to Meteorite Man
It's a $12,000 car....Almost cost as much as the double-sided tape!
MY Gas Station Attendant Misses Me...
Chuck
Meteorite Man is offline   Reply With Quote
Old 08-11-2007, 02:20 PM   #10
DMart
same amount of posts lol
DMart's Avatar
Drives: 07 Meteorite Metallic LB
DMart is offline   Reply With Quote
Old 08-11-2007, 06:33 PM   #11
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Its only a $13 part, dont worry so much.
Old 08-12-2007, 11:39 AM   #12
ttufrosty
Well the price is good to know. I will probably just get the piece and forget the hassle of dealing with the dealership. Thanks for the info
Old 08-12-2007, 01:25 PM   #13
Chris07LB
Chris07LB's Avatar
Then if you want to change them to LED bulbs, or brighter halogens, follow my DIY on removing them and sealing them back up.
Old 08-12-2007, 02:44 PM   #14
kimona
kimona's Avatar
Your Toyota Service Manager should be able to take care of it quickly and hassle-free.
Old 08-12-2007, 03:42 PM   #15
Chris07LB
Chris07LB's Avatar
Yea, if he's nice enough to install it for free.
It's one plug to unclip once its off the fender..
Old 08-29-2007, 12:38 PM   #16
sambo42xa
Drives: 07 YARIS Automatic/LiftBac/Red
ttufrosty, Chris07LB had a write up about this lamp awhile back; removal to change out/replace bulb etc. You should check it out. From what You explained, YOU May have cracked it when it got hit/moved. They come off by sliding them. So, You May have cracked it when you brushed up against it accidentially. But anyway, just thought I would mention the write up.
(Correct me if I'm wrong)
sambo42xa
sambo42xa is offline   Reply With Quote
Old 08-29-2007, 01:33 PM   #17
Chris07LB
Chris07LB's Avatar
I think somewhere in the DIY I also showed how to remove them..
Old 08-12-2007, 08:07 PM   #18
Shijima
Drives: 07 HB
Or you could go one step further, take out the light entirely, and then get a body shop to cover the hole for a clean look.
Shijima is offline   Reply With Quote
Are the optional airbags worth it ? avenno2g7 General Yaris / Vitz Discussion 46 12-07-2008 02:40 AM
Side curtain airbags not available? arothman New YARIS Purchase Forum 18 06-15-2007 03:46 PM
so close, cant decide roxy84 General Yaris / Vitz Discussion 31 04-13-2007 08:22 AM
Signal electrical questions Blenjar In Car Entertainment + Electronics (audio / video / alarm) 3 01-19-2007 01:06 PM
Side Turn Signal Lights bigsky2 Cosmetic Modifications (Exterior/Interior) 15 08-24-2006 06:06 PM
