Old 04-10-2007, 11:40 PM   #127
static808
Engineer/Artist/House-Dad
static808's Avatar
Drives: 2006 Toyota Sienna XLE
damn kaotic, look what you done started?? its right up there with the synth vs. dino debate. makes for fun reading though...
--B
His: 2006 Toyota Sienna XLE Arctic Frost Pearl, FC Package, 2007 Solara Nav unit, Spoiler, Running Boards & Auto-dimming rear mirror
Hers: 2007 Toyota Yaris LB Black Sand Pearl, Auto, Power Package, Side Airbags, VIP security, USDM center armrest, and accessory 7 spoke 15" alloy wheels
static808 is offline
Old 04-10-2007, 11:44 PM   #128
--B
lol...would have never thought i could start all this.
Kaotic Lazagna is offline
Old 04-10-2007, 11:47 PM   #129
static808
static808's Avatar
we need to keep you out of the UN. you mean well, but you'll be starting wars by accident!!
--B
Old 04-10-2007, 11:52 PM   #130
hahaha, the United Nations...hmmm, perhaps, i might start WWIII if i join the UN. lol...
Old 04-11-2007, 10:46 AM   #131
Adriaan
In between cities
Adriaan's Avatar
Drives: 2006 yaris ce
my experince with premium
personally i like the premium gas, i've has lots of problems with the regular gas here in ontario. The gas here is mixed with ethanol some times up to 15% except shell premium and i believe pioneer. i was having problems with the gas sensor. Took it to the dealer to find out that the since i was mixing fuel with and without ethanol the fuel turned a white color and had damaged the sensor. i work between montreal and toronto. In Montreal there is no ethanol in the fuel as of yet. Since i had it changed i stop buying regular here in ontario and haven't had the problem since. Also I work for esso and i found out that when you mix ethanol fuel like sunoco with regular fuel with out ethanol turns a white color, and as of yet there no technology to separate the two. But this is my experience and what i found out. Not sure if it is true with what i found, or my car was and isolated incident. Also i did a test with sunoco ultra 94 and shell premium on my last trip to montreal. Between my monteal house and toronto house is 686km with ultra 94 i got 536km and with shell i got 636km same driving style going and return about 120km to 140 km on the 401.
Adriaan is offline
Old 04-11-2007, 11:00 AM   #132
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
well u see...
as per (Adriaan's) quote.
"he personally i like the premium gas, i've has lots of problems with the regular gas here in ontario. The gas here is mixed with ethanol some times up to 15% except shell premium and i believe pioneer. i was having problems with the gas sensor. Took it to the dealer to find out that the since i was mixing fuel with and without ethanol the fuel turned a white color and had damaged the sensor. i work between montreal and toronto. In Montreal there is no ethanol in the fuel as of yet. Since i had it changed i stop buying regular here in ontario and haven't had the problem since. Also I work for esso and i found out that when you mix ethanol fuel like sunoco with regular fuel with out ethanol turns a white color, and as of yet there no technology to separate the two. But this is my experience and what i found out. Not sure if it is true with what i found, or my car was and isolated incident. Also i did a test with sunoco ultra 94 and shell premium on my last trip to montreal. Between my monteal house and toronto house is 686km with ultra 94 i got 536km and with shell i got 636km same driving style going and return about 120km to 140 km on the 401."
Originally Posted by Pavel Olavich View Post
So less efficient combustion means "cleaner"....Nope!
marcus is offline
Old 06-22-2007, 02:45 AM   #133
dallas
Drives: Yaris Hatch /Landrover D2
Let's stop the b.s and start posting our mileage figures on the two grades of gas. Enough people checking it should make the results more believable
dallas is offline
Old 06-22-2007, 10:46 AM   #134
marcus
toyota
marcus's Avatar
well i have been switching from prem to reg... so far i got more mileage with the prem then again that could also be driving habit as well..but its about 10-30 km difference for about 38 liters of gas..
here:
1st tank 540km with 39.8l fill up = 38.34mi/gal with regular 87 octane
2nd tank ran 535km fill up 38.4l = 39.37mi/gal with premium 89 octane
3rd tank 540km 37.5l fill up=40.69mi/gal with premium 89 octane
4th tank 570km premium fill up @38.00 liters =42.40 m/gal -15km/liter 89 octane
5th tank went to regular gas..48.2 liters ran 711 km 40% hwy (had to add 10 liters in between), calculated about 6.7l /100km,,41.68m/gal ... i was expecting about 6.0 l/100,,,atleast...
marcus is offline
Old 06-22-2007, 04:44 PM   #135
jdium
Mr Attitude
jdium's Avatar
Drives: Blazing Blue 5 Spd
[QUOTE=Kaotic Lazagna;69781]
Originally Posted by fu_im_from_texas View Post
not sure why either. my factors remaind the same, for the most part. the only difference is that i was driving faster and the gas itself. but i'm not willing to get another tank of premium to find out. lol...
I'm doing some math...the Yaris has an 11 gallon tank..."premium" 93 octane gas is usually .20 cents more per gallon than "regular" 87 octane gas...that's $2.20 a tank...
If you get 10% better gas mileage with premium, as some have stated (36mpg with regular, 40mpg with premium, etc), then you will be driving as far on 10 gallons or premium as you would be on 11 gallons of regular...
Stop me if I'm losing anyone...
Gas is now above $3 a gallon around my area. You are saving .80 cents if you see 10% better mileage with premium...
I'm thinking this is along the lines of the placebo effect, you believe your more expensive purchase is going to help you, so it does...
Also, how much do you all drive if an extra $2.20 a tank for premium is breaking your wallet? If you drive 10,000 miles a year at 40 mpg, that is about 23 fillups. That is $50 a YEAR...
Sorry for the ramble...but if you believe that premium is helping you, buy it. Scientifically, there is no benefit to running premium in these cars...
jdium is offline
Old 06-22-2007, 06:37 PM   #136
churp
Clean and (dis)Functional
churp's Avatar
[QUOTE=jdium;101220]
Don't understand how you can say that! Scientifically, under load the higher octane allows more timing advance before knock (in a 10.5:1 compression ratio car) which is more efficient, using less fuel for the power needed....not under load I agree with you.
____________
Old School Cobble Jockey
churp is offline
Old 06-23-2007, 01:03 AM   #137
hey, i never said that. hahaha...why is my name highlighted and not jdium?
but yeah, this thread was brought back from the dead. well, i used premium again and got less mpg. but i know that's because i've been using the a/c more. personally, i think i'm just going to stick regular.
Old 06-23-2007, 04:06 AM   #138
jdium
Mr Attitude
jdium's Avatar
[QUOTE=churp;101248]
It is a 105 hp engine, it is ALWAYS under load :D
If what you say is true, why don't the Toyota engineers tell us to use premium?
jdium is offline
Old 06-23-2007, 08:21 AM   #139
maybe because it would turn potential buyers away from the car, you don't usually associate a modern economy car with premium gasoline... Just a guess anyway! I'm gonna try higher octane fuel just for the heck of it for my next tank...
eTiMaGo is offline
Old 06-23-2007, 09:01 AM   #140
njyaris
YARIS NEWBIE
njyaris's Avatar
Drives: YARIS 07 LIFTBACK
Send a message via AIM to njyaris Send a message via Yahoo to njyaris
just my two cents ... i just bought my YARIS a week ago and I LOVE IT .. therefore i use 93 octane .. now does this change anything .. ofcoarse it does .. even if it's only perception .. since my perception is in favor for better gas milage and higher performance i tend to drive a little harder and faster .. just my two cents
njyaris is offline
Old 06-23-2007, 04:16 PM   #141
jdium
Mr Attitude
jdium's Avatar
Your perception is for better gas mileage so you drive harder??? That's counter productive...
Like I stated above. The higher mileage being noted is IMO a placebo type effect. You think higher octane will help, thus it does.
If requiring higher octane would turn away potential buyers, why not atleast tell them what everyone in here is saying? Increased octane = increased mpg? Cuz it's not true...
jdium is offline
Old 06-23-2007, 06:49 PM   #142
smokinyaris
smokinyaris's Avatar
Drives: bad boy
so do you guys feel up with premium or regular............
smokinyaris is offline
Old 06-23-2007, 07:36 PM   #143
jdium
Mr Attitude
jdium's Avatar
I feel up my girlfriend sometimes
I fill up with regular, the cheapest stuff I can find...
jdium is offline
Old 06-23-2007, 07:54 PM   #144
forpinks
forpinks's Avatar
Drives: 03 Toyota Corolla S modded,
Go buy a "Maximum Boost" book and it will tell you that a higher octane gas will give you more power compared to lower octane gas.
there is a comparison on the N/A and Turbo there really is a big difference especially if your running RPMs higher than 4500 on N/A... The turbo with high octane gas is damn more powerful than low octane.
Also the 106HP (not high performance? I know.) is achieved using high grade high octane gasoline for testing (Since Japan don't have anything lower than 93 octane they even have 120-125 octane) the engine power will drop to 100flywheel HP when you use 87 gas and it will make more gunk to the engine because of the slight combustion difference even with the knock sensors, remember the 1NZ-FE is japan made and tested so It should run 90+octane and will get 51MPG elsewhere except US (may be possible with acetone) which don't have anything higher than 93 basic fuel 100 octane cost like 4.30 vs 3.30 91...
(It's new here in the USA and Toyota USA wouldn't put the 91 reccomended fuel since it will hurt sales...)
Hope this helps!!!
THE YARIS: TINY BUT PRICEY!
BUT YOU JUST GOTTA LOVE IT....
forpinks is offline
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 06:41 PM
I'd like to know this right now.. is brand name gas better for my new Yaris? fantabulousbaby General Yaris / Vitz Discussion 12 09-19-2006 09:14 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 08:07 AM
Tired of poor gas mileage & buying premium gas. Boosted Peon New YARIS Purchase Forum 29 08-25-2006 08:59 PM
poll concerning gas prices foober General Yaris / Vitz Discussion 15 07-24-2006 12:47 AM
