#19 |
Hi!
since it's not a track car, the really minor rubbing on the splash guards isn't a problem for me. i've had this type of rubbing, and alot worse, in many different cars so i'm used to it. if i wanted to put her on the track, i'd raise up the height and/or remove the splash guards anyway. i'd have to say no to the camber bolts to try and save as much tire as i can. but they would definitely work for you.
#20 | |
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
no camber bolts for me either now that I have the basics installed , I'm not concerned with rubbing
SPONSORED BY
#21 | |
![]() ![]() Drives: 07 RS Join Date: Jun 2007
I also assume that these are in stock height? now will lowering with the TRD springs 30 mm front and 30mm rear effect this?
Honda to Toyota... lets see how this plays out
#22 | |
Lonesome Cowboy
most aftermarket wheels are going to be 7 inches wide and that changes things a bit even with the same offset, also tire width and profile and how low you go, all things would have to factored in, I think lowering on TRD springs with any offset within reason should be fine up to a 16 inch wheel, you are still going to have quite a gap there
SPONSORED BY
| How to determine proper wheel offset? | Yaris Revenge | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 05-23-2009 10:41 AM |
| Yeah, I know... I'm a sellout. | ChinoCharles | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 53 | 06-21-2007 12:29 PM |
| Carbon offsetting with TerraPass | BailOut | General Yaris / Vitz Discussion | 14 | 05-28-2007 12:29 AM |
| Offsets? | Yarisagos | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 03-12-2007 08:06 AM |
| Wheel Offsets | bigsky2 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 03-08-2007 01:55 AM |
