Old 07-18-2007, 03:28 PM   #19
death is my gift
wacky broadway nightmare
death is my gift's Avatar
Drives: Willow is a '07 Red Yaris LB
Send a message via AIM to death is my gift Send a message via MSN to death is my gift Send a message via Yahoo to death is my gift
Originally Posted by grampi View Post
I would be shocked if the Yaris doesn't have clearcoat on it. Every car I know of built within the last 10 years or so has had clearcoat.
Ah, good to know. Learning is fun.
"it's always complicated and at some point someone has to draw the line and that is always going to be me. you get down on me for cutting myself off but in the end the slayer is always cut off" Buffy
death is my gift is offline   Reply With Quote
Old 07-18-2007, 03:33 PM   #20
sherryberry
sherryberry's Avatar
Drives: 07 Blazing Blue Yaris
Send a message via AIM to sherryberry Send a message via MSN to sherryberry Send a message via Yahoo to sherryberry
that's what i thought too but why are people sayin there is no clearcoat?
sherryberry is offline   Reply With Quote
Old 07-18-2007, 03:36 PM   #21
death is my gift
Cuz like me they were misinformed? Don't really know.
Old 07-18-2007, 05:13 PM   #22
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
Yes there is a layer of clear coat on the car.
SPONSORED BY
Old 07-18-2007, 05:30 PM   #23
sherryberry
brick comes to the rescue!
Old 07-18-2007, 05:38 PM   #24
Meteorite Man
Passin' The Gas...Station
Meteorite Man's Avatar
Drives: Same As You But Different
Send a message via Yahoo to Meteorite Man
That plastic wrap stuff sure does distort the Yaris.
Chuck
MY Gas Station Attendant Misses Me...
Chuck
Meteorite Man is offline   Reply With Quote
Old 07-18-2007, 05:40 PM   #25
Meteorite Man
A real fine gentleman he is.
Just watch how fast he can get your pussy out of the tree.
Chuck
Chuck
Old 07-18-2007, 05:41 PM   #26
death is my gift
So, why not put more than one layer of a clear coat?
Old 07-18-2007, 06:26 PM   #27
brickhardmeat
Lonesome Cowboy
I am not certain that there is only one layer of clear but there can't be much. Why? Cost.
I had a scratch on my bumper probably bumped a tool installing struts or it happened pulling stuff in and out of the hatch area. It ws -very- easy to remove with Scratch X. Took me about 2 min. and it vanished.
SPONSORED BY
Old 07-18-2007, 08:36 PM   #28
churp
Clean and (dis)Functional
churp's Avatar
Brick and Grampi are right, there is a clearcoat....just not a durable one. Best to talk to a good bodyshop about what's best. I vote for a good 2 part urethane....read an article when they first came out, street rodders were using it on frames and suspension components, they could actually beat on the frame after it was cured with a hammer and not leave marks....very tough. And the thinner the layer of paint the better!!!
____________
Old School Cobble Jockey
Old 07-19-2007, 08:04 AM   #29
grampi
Drives: Corolla
The problem in doing that is you're basically using an abrasive to remove some or all of the clearcoat (depending on how deep the scratch is) surrounding the damaged area so you no longer see the scratch. Not only is a very thin clearcoat being used by the auto makers to save money, they obviously aren't using the most durable stuff either. I'll let you guys know what I find out about having the entire front end and hood done up with the good stuff by a paint shop.
grampi is offline   Reply With Quote
Old 07-19-2007, 08:49 AM   #30
brickhardmeat
Lonesome Cowboy
There is still some clear there and I'll give it a thick coat of wax. The scratch wasn't bad. Yes these products create many fine scratches to make the larger scratch fade disappear. You should see the underside of my front bumper. There is no saving that.
SPONSORED BY
Old 07-19-2007, 09:09 AM   #31
grampi
Drives: Corolla
If all the color is still there, you may be able to save it with a good coat of some good clearcoat.
Old 07-19-2007, 09:21 AM   #32
brickhardmeat
Lonesome Cowboy
No bottom of the bumper has been scraped profusely. No paint left just plastic. Doesn't show.
SPONSORED BY
Old 07-19-2007, 04:30 PM   #33
grampi
Drives: Corolla
Oh, how'd that happen?
Old 07-19-2007, 04:42 PM   #34
brickhardmeat
Lonesome Cowboy
driveways mostly
SPONSORED BY
Old 07-20-2007, 10:24 AM   #35
Imagine
Insert sarcasm here.
Imagine's Avatar
Drives: 2009 Black Pearl Sand 3Dr
Two types of paint is used in painting cars usually.. Base coat / Clear coat and Enamel. Enamel does not get cleared. I don't know of any manufacturer that doesn't use base coat/ clear coat. I'm not a professional body man, just do the stuff for fun but I don't see any reason why you couldn't lay a couple of coats over the stock. Just wet sand the stock clear and spray a couple coats of more durable clear coat. You'd be amazed how much better good clear would make the paint look too.
Imagine is offline   Reply With Quote
Old 07-23-2007, 05:38 PM   #36
thatboyjer
thatboyjer's Avatar
Drives: 5spd 2007 Yaris LB
i just wash my car at the neighborhood wash, high pressure rinse, foam brush (which i thouroughly clean first with the HP rinse), high pressure rinse again, clearcoat protective wax, Spot free rinse, air dry by driving around.
End result? car looks great and i don't get any of those swirly looking scratchs from drying the car with a cloth. I hit all sorts of debris while driving to work on the dirt roads for 15+ miles in the mornings but the paints really holding up still looks great.
i think it all depends on maintenence.
thatboyjer is offline   Reply With Quote
New 2007 Paint Condition Pavel Olavich DIY / Maintenance / Service 16 09-13-2009 04:14 PM
Buyer Beware: Huge paint defect on brand new Yaris voodoo22 General Yaris / Vitz Discussion 31 07-30-2007 08:24 PM
OK Heres My Ride!! marcus Photo-Video-Media Gallery 20 05-07-2007 05:29 PM
paint shop!! yrsdrgn California 3 05-03-2007 10:40 AM
