Old 07-24-2007, 10:00 AM   #1
ChinoCharles
Drives: LB
Revs
Question I've had for a long time... look at chaikrab's tach.
Do overseas Yarii actually rev to 8 grand or is there just 1500 RPM's of wasted tach? I've never seen a car top out right at redline.
Old 07-24-2007, 10:23 AM   #2
kurokoma-kun
Drives: 2007 Yaris HB
Isn't the redline at 6.5?
my yaris, kurokoma-kun
Old 07-24-2007, 10:52 AM   #3
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
I think my sedan buries at 8 grand. What about the liftbacks??? I also
thought 8 grand was unusual.
slvryaris is offline   Reply With Quote
Old 07-24-2007, 10:59 AM   #4
steved
Yaris Rules!!
Drives: 2007 Red Yaris Liftback a/t
My LB is at 8 also, but I believe it is more for looks then anything else.
As kurokoma-kun it redlines at 6.5.
steved is offline   Reply With Quote
Old 07-24-2007, 12:03 PM   #5
never tried going over the redline, but I think it can...
Old 07-24-2007, 12:47 PM   #6
kurokoma-kun
Try it! the rev limiter kicks in to save you from yourself
Old 07-24-2007, 12:59 PM   #7
REM
REM's Avatar
Drives: 2012 Nissan Leaf SL
Don't all cars have a red line and then go past it on the tach? I know my last car went 1-2,000 RPM past the redline, and like kurokoma-kun said it wouldn't let me go over it.
Cheers,
Ryan
REM is offline   Reply With Quote
Old 07-24-2007, 03:12 PM   #8
YarisGuy
Drives: 2006 Yaris
Every car has 1500 to 2000 past redline on the tach, it looks cooler! There should be something called a rev limiter a few hundred after 6500 to stop you from dropping valves.
It's a red yaris
YarisGuy is offline   Reply With Quote
Old 07-24-2007, 09:17 PM   #9
slvryaris
slvryaris's Avatar
I think Chino was saying that its weird how they stopped at 8 grand but the line continues so it looks like it goes to like 9 grand.
Old 07-24-2007, 10:21 PM   #10
ChinoCharles
Drives: LB
What I was saying was that on any other manual car I've driven with a tach the revs didn't stop at redline. For example, my old Eclipse I believe redlined at 6,000 RPM and TOPPED OUT at 7,000. What the hell is with the Yaris redlining and limiting out at 6500 RPM?
Old 07-24-2007, 10:26 PM   #11
slvryaris
slvryaris's Avatar
hmmmmm......
Old 07-24-2007, 10:31 PM   #12
ChinoCharles
Drives: LB
... and the major question... can the 1NZ handle 8,000 RPM? Is the reason for the low revs due to engineering or an FE-geared setup?
Old 07-24-2007, 10:53 PM   #13
bearda
bearda's Avatar
Drives: 2006 Mazda3 Sedan
Manual, automatic, that's how it's worked in every car I've driven with a tach. What's the point of showing the extra 1500 RPM if you can't use it?
bearda is offline   Reply With Quote
Old 07-24-2007, 11:43 PM   #14
Quatro
Quatro's Avatar
Drives: '07 Yaris LB Manual
You can if you remove rev limiter.
Quatro is offline   Reply With Quote
Old 07-25-2007, 12:36 AM   #15
slvryaris
slvryaris's Avatar
Has anyone seen the you tube videos of people showing off their exhaust and they just peg the needle and keep it there for a sec???
Old 07-25-2007, 09:47 AM   #16
kurokoma-kun
I wasn't gonna mention it--no doubt CC is out there attempting it now
Old 07-29-2007, 06:59 AM   #17
naossoan
Drives: 07 Yaris 3DR
Um, yea mine is the same I'm in Canada.
Look at the speedo, it does the same thing. You think a stock Yaris is gonna go 200K? I'm not so sure about that.
naossoan is offline   Reply With Quote
Rev-Matching MrJester General Yaris / Vitz Discussion 3 04-23-2007 01:44 AM
To accurately measure MPG when should I fill back up. mgthompson General Yaris / Vitz Discussion 17 03-30-2007 11:07 PM
