![]() ![]() Drives: Black LB Join Date: May 2007
Coolant Light
Is it normal for the coolant light to stay on longer than usual when you first start the car up while its cold.Mine stays on for about 2 min or so,I called the dealership they said it is normal .Is this true or they just
Yaris Rules!!
Drives: 2007 Red Yaris Liftback a/t Join Date: Jun 2007
Yes it's normal, The colder it is outside, the longer the motor takes to warm up.
Thank you not use to the light staying on that long
Yaris Rules!!
you should see how long it stays on in winter time here.
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
locked
SPONSORED BY
![]() ![]() ![]() Drives: yaris 2 door hatch Join Date: May 2007
Texas 96 hot light stay on 1.30 min by the time I reach the main road its gone. Ready to roll..
yes normal - there no temp gauge on the yaris just a light to tell you whether it is cold or hot.
If there was a gauge the needle would sit at the bottom for a couple of minutes on a cold engine and slowly move to the middle wouldn't it? - wish the yaris had one though.... |
| Check engine light flashes during high reving | AlphaFox | DIY / Maintenance / Service | 40 | 08-21-2007 02:43 PM |
| Engine Coolant Temperature | djino | General Yaris / Vitz Discussion | 18 | 07-16-2007 01:26 AM |
| Reverse light vs Rear Fog light | cooldavidko | General Yaris / Vitz Discussion | 3 | 01-03-2007 04:09 AM |
| "Airbag" center console light on 07 Sedan with side airbags | atebit | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 11-10-2006 07:10 PM |
| Coolant Light | Cathy | DIY / Maintenance / Service | 15 | 09-04-2006 01:28 AM |
