![]() ![]() ![]() ![]() Drives: 2007 Yaris Sedan "D" package Join Date: May 2006
alternator same in scion xb, and yaris???
can someone in the know, look up the part numbers for the scion xb, the yaris, and the echo, to see if the alternators are the same part number...
I have been looking for a HO alternator, and they make them for the scion's including the xb, which shares the same engine... thanks again |
Resident Scion Guy
Drives: 2008 Mazda3 S Sport Join Date: Mar 2006
Call the Parts dept of your local Toyota Dealer & ask them for the part numbers for each. That will tell you.
BTW, are you looking at the Iraggi one??
Code:
DiabolicJourney_SpaRky |
I've searched many car audio sites and they recommend staying away from Iraggi...
I have found 1 place but they want $600 for a 180amp alternator...its a rewind... |
Resident Scion Guy
Ouch. What are you installing?? a wall with 12 12"s??
Code:
![]() ![]() Drives: 07 Polar White Yaris Hatch-3DR Join Date: Jul 2006
im looking for something like this too im only running 2 1000 watt 12's (type r's)with a 1000 w rms rockford fosgate amp and my lights dim what else is involved in doing this kind of upgrade i dont want to have electrical problems thanks for the help..
Resident Scion Guy
Get a 2nd battery & a battery Isolator, you'll be fine.
Code:
ok, iraggi just emailed me back, if its the same as the echos', and XB then the price is :
180 $399 200 $419 http://www.highoutputalternator.com/ gave me a price of :$649 |
#9 | |
the route i am taking so far, is a 0 guage wire from the battery to the trunk, splitting to 2 4 gauge wires to my amps... For now, i will probably use a 1 farad cap, but will upgrade to a high outpout alternator, and dual battery set up. Last edited by punch; 07-27-2007 at 09:37 PM. Reason: correction |
![]() ![]() ![]() ![]() ![]() Drives: NST CARS: S13 AE86 ANT10 AW11 Join Date: Dec 2006
The problem you guys have at idle with dimming lights and weak batteries is because your OEM alternator does nothing at/near idle. Your alternator does not start charging until around 1200 rpm.
Your best bet might be to look for a reputable pulley builder. Such a company would be able to build you an Overdrive Alternator Pulley for your stock alternator. A properly built Overdrive Alternator Pulley would cause your OEM alternator to charge at a lower rpm (maybe 900rpm) and would save you time, hassle, and customization required to fit a different alternator. Good luck gang! |
Mr Attitude
Drives: Blazing Blue 5 Spd Join Date: Jun 2007
till your alternator burns up...
It's scary to think that half the people surrounding you are below average...
thanks nonstoptuning i like that idea. has anyone found out what the rateing of the stock is yet and how much would it be safe to jump up with out having to rewire engine power. thats what i was originaly asking if i swap out my alternator what else do i have to change. im going to get a grounding kit and a 1 farad cap and try it but if an alternator swap is necessary i would like to know whats involved.
#13 | |
#14 |
so the higher amperage alternator wont burn up stock wiring??
#15 |
sorry i can do all the other stuff and im good with wiring but never upgraded alternator just wanna make sure
#16 |
Give Me Resonance
you can try calling iraggi, I got mine from him but I have an 07.
![]() (3) 12" Alpine Type R Subs/Hifonics BXi1208D Hifonics ZXi6.5c / 2006 Kicker ZX350.4 Knu Fleks 1/0 Wiring & In Big 3 Optima Yellow Top Battery/Iraggi HO Alternator Alpine CDA-105, KCA-420i/KCA-121b/KCE-400BT PG TLD22 8V Line Driver |
