#55 |
![]() ![]() ![]() ![]() Drives: 2007 Yaris manual dark silver Join Date: May 2006
where did you hook up the illumination wire and HOW did you do
im new to the hole wiring thing and a step by step diy for just hook the two wires would be cool
7 Color Tach Fujita Intake Momo pedals Shift knob and boot. Full TRD SSK. Blitz exhaust Megan Lowering Springs (Next is DC Header) |
#56 | |
Attach the tachometer "Illumination" (yellow wire) to the other add a fuse circuit. Install this add a circuit at terminal 8 or 9 (the red 10amp circuit across from #24 location). This will ensure that the tachometer "remembers" what color it was last on after you shut the car off. |
#57 | |
#58 |
Thanks for the DIY!
just installed my glowshift 7 color tach. gotta love wire testers :) posting pics after i make the wires invisible. woot woot |
#59 |
That Anime Guy
I installed my Speedhut gauge this weekend with the help of this DIY. However, my gauge has two Illumination wires and two grounds. I guess one for the gauge and one for the shift LED. The LED's light up fine and so does the needle, but the backlight is very very dim. Any advice?
#60 |
That Anime Guy
Bumpity Help Me!
#61 |
i just got my speedhut guage in the mail today
im installing it tomorrow. ill let you know what i find
07 Yaris LB 5spd AE86 Corolla GTS 5spd http://microimage.ning.com/ http://www.microimageonline.com/store.html |
#62 |
glowshift coming next week, will post install pics also. I want mine on the other side of the steering wheel if possible though, that's where I'm used to looking on my other cars.
#63 |
![]() ![]() ![]() Drives: 07 Yaris HB Join Date: Apr 2007
you know i was just thinking that and i had a thread posted for it under cosmetics and in the a-pillar guages thread
Rice on, Rice Off Ron Cabading |
#64 |
Rwseattle
Drives: 2007 Toyota Yaris (BASE) Join Date: Dec 2006
Yes, post pic. I'm interested in the speedhut tach.
#65 |
Argentina Presente!
Drives: 07 White LB Join Date: May 2007
one small question.. how do you guys attached the green tach wire? I know where it goes, but how is the best way to attach it? cut the blue-green wire from the ECU, then attaching all 3 ends together?
thanks! |
#66 |
best way is to soldier it/ shrink wrap together, but they also sell 3-way t-type crimp connectors that will work good too. whatever you prefer. just dont twist it and elec. tape it
#67 |
Argentina Presente!
well.. i followed the instructions and the tach is not working.. one stupid question, the fuse (#24) i took from the box i need to attach it to the "add a fuse".. right? (i did it), is any special direction the fuse goes?
another question.. for the ground I needed to add some wire... but the wire is thicker that the tach black wire... that is a problem? I tried everything... and nothing, the needle doesnt move, and no ilumination also.. Im using the glowshift. Any has this problem? |
#68 |
I've sent one glowshift back already, but yours is probably not the unit. Shouldn't be a problem with your ground wire size.
Have you hooked up 12v to the tach to make sure it lights up? Do you have a way of testing a wire to see if there's juice in it?
#69 |
Argentina Presente!
Red wire in #24.. with the 7.5 amp.
Yellow wire in #9 with the 10 amp. * what happen if i do a wire jump in the "add a fuse" instead of puting the fuse? i guess i will need to buy a tester to see what is going on.. |
#70 |
Argentina Presente!
finally! is working! My mistakes, I didn't put the fuse in the slot B of the "add a fuse".. and then, I had to turn 180 the "add a fuse"..
It looks great!!!! I will post pictures later.. |
#71 |
Argentina Presente!
well.. the radio now is not working.. ggrrr.. i need to read the other thread about the radio.. :/
#72 |
![]() Drives: 2007 Meteorite metallic Join Date: Jul 2007
Those Grote add-a-fuse things are $22 each here at NAPA. I'd need two and I didn't pay that much for the tach. Anybody know of any place to buy them for a reasonable amount?
| Liftback Spoiler Installation | Toddhata | Cosmetic Modifications (Exterior/Interior) | 25 | 08-09-2009 01:26 AM |
