Old 08-07-2007, 06:36 PM   #109
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Originally Posted by jeremyshay View Post
got any other fun projects?!
Yes actually.
Old 08-07-2007, 07:02 PM   #110
Christopher
Cobra
Drives: '07 3-door
DRL
Thanks for the info! I assume the headlights still go on and off by using the switch on the stalk? Chris
Christopher is offline   Reply With Quote
Old 08-07-2007, 07:05 PM   #111
Christopher
Cobra
Drives: '07 3-door
Thanks for the info!! I assume the headlights still go on and off by using the switch on the stalk? Chris
Old 08-07-2007, 07:05 PM   #112
Chris07LB
Chris07LB's Avatar
Everything is exactly the same.
Only difference is when you start the car, you dont have ugly DRLs on.
Old 08-07-2007, 08:35 PM   #113
jeremyshay
jeremyshay's Avatar
Drives: 07 Meteorite Metalic Liftback
Send a message via AIM to jeremyshay
Originally Posted by Chris07LB View Post
Yes actually.
teach me
jeremyshay is offline   Reply With Quote
Old 08-07-2007, 10:31 PM   #114
GabL
I want JDM bumpers!
GabL's Avatar
Drives: 5 Dr Yaris RS in Blazing Blue
THANKS!!!!!
any weird side effects of this?!
cause if not im totally on it the second i wake up tomorrow.....
The side effect will be you will lose your fog light if you have the factory equipped ones.
GabL is offline   Reply With Quote
Old 08-08-2007, 03:32 AM   #115
jeremyshay
jeremyshay's Avatar
sure dont... MAY be coppin some ebay fogs soon tho...
Old 08-08-2007, 06:53 AM   #116
Chris07LB
Chris07LB's Avatar
Even better.
I did the same, and now can put my fogs ON/OFF whenever I want.
Old 08-08-2007, 12:48 PM   #117
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
Even better.
wth? was there a cutoff line in teh us somewhere for parts fo the country to get drl equiped cars? none of the ones here in Florida (that I've seen on lots) have drl....
I wanna put the fogs on whenever too, damnit....
Old 08-08-2007, 02:04 PM   #118
Chris07LB
Chris07LB's Avatar
Re-read from the start of this post. I think we came to the conclusion, that all US Spec cars with cold weather package came with DRL's... either that or they all just came with DRLs.. i dont remember which now.
But by disabaling the DRL's, it has had an effect on factory installed fog lights, but no issues at all with the eBay or JimCatt kits.
Old 08-08-2007, 02:53 PM   #119
jeremyshay
jeremyshay's Avatar
i think whats really important is that i need to learn these extra projects you've talked about chris
Old 08-20-2007, 06:46 PM   #120
tapuleo
tapuleo's Avatar
Drives: 2007 White Liftback
Got my Yaris in Washington and it has DRL's. I don't mind 'em though, but have been caught at dusk a couple of times because I forgot to turn the rest of the lights on. At night it's easier to not forget because I can't see anything else on the dash. :)
I suppose if I were a criminal, and wanted to sneak around in my Yaris at night, I'd want to pull the plug...or even a potential victim, hiding from a criminal, it'd be nice to be able to shut off the lights. I've seen way too many movies.
tapuleo is offline   Reply With Quote
Old 09-18-2007, 08:20 AM   #121
joey1320
joey1320's Avatar
Drives: Yaris LB
at first i didn't mind them but then i got my fog lights and i wanna just use the fog lights and the drl take away from the look of them... thanks!
joey1320 is offline   Reply With Quote
Old 09-18-2007, 08:35 AM   #122
Chris07LB
Chris07LB's Avatar
np.
Old 11-13-2008, 09:55 PM   #123
metalshark
MetalShark
Drives: 2008 Yaris LB
I got a warning ticket last night because of DRLs. When they are on I see lights but have no tail lights hence the pull over.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline   Reply With Quote
Old 11-15-2008, 03:38 PM   #124
Rotorheader
Drives: 07 Yaris Hatchback
That exact same thing happened to me last night, except I didn't get a warning ticket ~ just a "Go and sin no more." This morning, I removed the relay and did a quick test run; No problems.
Rotorheader is offline   Reply With Quote
Old 11-15-2008, 05:05 PM   #125
Snyprwlf47
The Martian
Snyprwlf47's Avatar
Drives: 07 Yaris 3dr
Send a message via AIM to Snyprwlf47 Send a message via Yahoo to Snyprwlf47
Im gonna go do it right now....Whats the use of hiding from the cops at night if your DRL are as bright as your headlights. ^_-
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker.
Snyprwlf47 is offline   Reply With Quote
Old 11-16-2008, 08:59 PM   #126
Rotorheader
So did you do it???
Toyota unveils 2007 Yaris T-Sport Concept VitzBoy General Yaris / Vitz Discussion 63 01-21-2007 03:12 PM
