Old 08-16-2007, 12:04 AM   #19
uncleyaris
I know Ric N Sov has them check his garage, or check out the GTA meet pictures from Jun. I think there are some pics there!
Old 08-16-2007, 04:00 AM   #20
seanele
seanele's Avatar
Drives: '07 Blazing Blue LB, '09 Jetta
you can take a look at my garage. or take a look at my myspace in my "car pics" album.
www.myspace.com/kaoticlazagna
i think that's it.
man..you have a nice myspace background photo there!
current: '07 Yaris LB - '09 VW Jetta
ex: '06 Beetle S(19x8.5 Audi A8) - MK4 GLi BMP(18x8 OZ, K04) - '03 GTi(17x7.5 Ronal, APR93) - '01 GLS - '88 GTi - '86 GTi - '83 GTi
seanele is offline   Reply With Quote
Old 08-16-2007, 04:55 AM   #21
hahaha, thanks. i think photobucket made my pic pixellated tho.
Old 08-16-2007, 10:19 PM   #22
Kaeon
Drives: 2007 Yaris Hatch
Damn I dunno why the Tananbe's look lower then Teins
Kaeon -
2007 Toyota Yaris Hatch
Kaeon is offline   Reply With Quote
Old 08-16-2007, 10:38 PM   #23
uncleyaris
There not on a stock set up!! 1.9 is the max i've seen!
Old 08-17-2007, 01:22 AM   #24
churp
Clean and (dis)Functional
churp's Avatar
i thought cutting a coil or two will make your car more bouncy.
Cutting coils effects the spring rate....makes it harsher/stiffer for the same amount of travel. Think of your spring as a torsion bar....if you straightened it out and tried to twist it, (usng the same diameter rod) the longer the rod the easier it is to twist, shortening increases the force required to twist to the same degree of movement.
____________
Old School Cobble Jockey
Old 08-17-2007, 02:01 AM   #25
BrazdonW
What kind of car is that?
Drives: Yaris 3d liftback
Originally Posted by seanele View Post
can somebody confirm this?? i already send back my Tanabe DFs..
only because people here said Tein is way better,in comfort..less bouncy and better handling than the Tanabe.
last Friday night at the meeting,
i test drive a Yaris with that DFs..and it felt okay actually.
and i was surprise when the owner suggested to get the Tein instead.
Most people i asked in here said Tein,
Autobacs said Tanabe,
my buddies at VW Vortex said Eibach or H&R,
i pick Tein..!!
Tein is the way to go for sure. Eibach and H&R will always be what a VW owner tells you to get.. but they are far from the best. (not bad mind you) Tanabe are good but Tein sustains the normal ride of the car best.
Old 08-19-2007, 04:50 AM   #26
seanele
seanele's Avatar
dude..thanks for this..
i got the Tein spring(finally..!!), and this time i want to keep it.
the Tanabe DF i bought the other day from friend in Jersey, i sent it back..
Old 08-19-2007, 11:13 AM   #27
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
once settled, my DF's dropped a hair over 2" all around.
some people like myself actually measure these things before and after...
Old 08-19-2007, 06:00 PM   #28
Kaeon
Any companies out there plan to make a more dramatic drop? or is this about it?
Kaeon -
Old 08-19-2007, 06:59 PM   #29
Chris07LB
Chris07LB's Avatar
Doubt it. Unless they package a spring/strut combo(matched set) for the front, and a spring/shock for the rear.
With DF's and over 25,000 miles on the stock struts/shocks, I haven't noticed any change yet in the ride, but I know these wont last forever.
If looking to go lower then 2", Id just suggest coilovers.
Old 08-20-2007, 01:22 PM   #30
Kaeon
Yeah I'm not wanting to throw that much money in a DD, To bad ground control or someone didn't make a kit. I guess its Tanabe's for now.
Kaeon -
Old 08-20-2007, 03:49 PM   #31
Trish
Drives: Yaris Sedan 07
Send a message via MSN to Trish
For myself, I dropped my Yaris with 1,3" Apex and it's not as low as I wanted. Next summer, I'll buy TEIN coilover kit. Do not cut anything.
Do it My Way on The High Way
Trish is offline   Reply With Quote
Old 08-20-2007, 04:08 PM   #32
YarisFan007
YarisFan007's Avatar
Drives: 2007 Toyota Yaris HB
Has anyone installed Dampers on their Yari yet? I want to drop my Yari but also want the ability to adjust the ride height for daily commute and for highway runs.
Anybody recommend a particular brand? I was thinking of getting TEIN's Dampers.
YarisFan007 is offline   Reply With Quote
Old 08-20-2007, 04:12 PM   #33
YarisFan007
...Actually, i might be talking about Coilovers instead of Dampers..... but which ever is used to adjust the height. : )
Old 08-20-2007, 04:15 PM   #34
Chris07LB
Chris07LB's Avatar
Few members here have them..
Megan, Cusco, Tein, etc...
Do a search on "coilovers" and you should see quite a bit.
New 07 Yaris S need advice on 18's and springs OgDogg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 48 04-27-2009 09:50 PM
Minimal Drop From Springs blacksan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 05-15-2007 05:46 AM
Tein Basic Damper Coliey's Vs. Tein S. Tech Springs ToTo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 05-07-2007 05:08 PM
Lowering Springs - Questions ~ AGAIN ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 01-16-2007 12:23 AM
FS: Spirit Lowering Springs 1.7" drop xCookiE Items for Sale by private party 2 07-24-2006 08:29 PM
