Old 08-23-2007, 08:08 PM   #1
Terrorize
Toyota Newb!!
Drives: Yaris S Sedan w/ Aero Package!
ATTN: Don't buy REAR Stoptech SS Lines!!
Just wanted to give a heads up to everyone thats interested in the Stoptech REAR Stainless Steel Brake Lines.
I just called Stoptech and confirmed that they made a big boo boo on their part for the catalog. Our cars being a rear drum setup we can't use the lines that they offer....the front lines should be ok...i'm getting those installed next week.
So far no news on developing rear drum lines as of yet...i am told.
Terrorize is offline   Reply With Quote
Old 08-23-2007, 08:33 PM   #2
thanks for the heads up
Old 08-23-2007, 11:15 PM   #3
Black Yaris
der Zeck
Black Yaris's Avatar
shouldn't we only have one rear brake hose? we have a solid rear dead axle, the line should go right up to the cylinder from a "T" and a Hose off the "T" to another line going to the Master Cyl.... I did not pay attention last time I was up under there..... but that is usually how things go, correct me if I am wrong
Old 09-01-2007, 02:08 AM   #4
Terrorize
Toyota Newb!!
No idea dude...i haven't taken a look yet...
I think i just might have to return the whole stoptech package and get the Goodridge set...as the kit they have includes the rear drum brake lines as well...
Old 09-01-2007, 02:18 AM   #5
alhope34
Spool'd
Drives: 07 yaris, 16 gen coupe rspec
How would ABS for the rear wheels work if both rear brakes were powered by one brake line? From everything I've ever been taught working in the Toyota garage, ABS needs 4 independent brake lines that all run to the central unit thing under the hood, usually near the brake booster...forget the name of it now. Looks like a block of aluminum with brake lines coming out all over it.
alhope34 is offline   Reply With Quote
Old 09-01-2007, 04:22 AM   #6
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
my tacoma had drum brakes, solid rear axle, and one brake line... but no abs as well.
reznunt is offline   Reply With Quote
Old 09-01-2007, 05:09 AM   #7
CF-Shane
CF-Shane's Avatar
Drives: 1993 Toyota Terecel 2 door
Send a message via AIM to CF-Shane Send a message via Yahoo to CF-Shane
I had a 93 S10 where, I shit you not, the ABS consisted of a speed sensor and valve (rear wheels only) that would quite literally shut off your rear brakes when they locked up. You'd be amazed at what manufacturers can get away with when it comes to naming parts in a sales brochure. Take the Yaris for example: I see a solid beam rear axle with coil springs, and Toyota's marketing department sees a "tortion beam rear suspension". Yeah, ok. When I hear that I think of tortion bar suspensions that are typically found in older Chrysler cars and modern 4x4 trucks, not a plain beam and springs suspension. It all comes down to properly applied naming or not, they'll call it what it needs to be called to sell vehicles.
CF-Shane is offline   Reply With Quote
Old 09-01-2007, 06:29 AM   #8
xed
xed's Avatar
Drives: '08 Polar White 3dr
Originally Posted by CF-Shane View Post
... they'll call it what it needs to be called to sell vehicles.
Salesman: Here is one of my favorite features on the Yaris. This is the new actuated rotating bidirectional beverage retention device. We call it ARBBRD for short.
Buyer: You mean the nifty cup holder?
Saleman: errr, yeah the nifty cup holder.
xed is offline   Reply With Quote
Old 09-01-2007, 11:42 AM   #9
WolfWings
WolfWings's Avatar
There's a difference. The Yaris' "solid beam rear" actually appears to be under torsional load from what I saw, looking at it after I had my TRD rear sway bar installed. The fact that the 'solid beam' is a near-duplicate of the rear sway bar but attaches to mounts more-or-less one-bolt-higher than the sway-bar shows it actually is a torsion beam, not a true 'dead axle' design. The fact that there is no mount for a track rod/panhard rod (Suspension SP-62) shows that (at a minimum) the rear suspension is a twist-axle rear, which means that, yes, the rear beam is designed to be under torsional forces like a torsion-bar setup.
The only difference between a 'twist axle' rear and a 'true' torsion-beam rear is if the rear axle is two parallel (at rest) rods cross-linked or one single rod. The two parallel rods gain a minor design-engineering-simplicity advantage at a moderate complexity disadvantage. The single-beam is, in effect, two half-length torsion bars linked at the mid-point by comparison, and more math and proper design can let it perform almost well as the two-rod setup AFAIK, though it doesn't add as much chassic-rigidity as the two-bar setup. This is (I believe) why a rear sway bar is so noticable on the Yaris.
Old 09-01-2007, 12:16 PM   #10
Engineer jargon overload
But I think I understand and agree with what you mean, take a look at the technical manuals for download in the DIY section, you can see that the hinges for the rear beam are angled, so there would be some torsional action when the suspension moves.
Old 09-01-2007, 04:44 PM   #11
WolfWings
WolfWings's Avatar
Go read the Car Bibles.com Suspension Bible and it'll help explain things.
Old 09-01-2007, 07:11 PM   #12
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
I thought there were 4 rubber lines for the rear. I dont remember for sure, as the last time I was looking back there was when I lowered it 6 months ago.
Old 09-02-2007, 02:19 AM   #13
CF-Shane
CF-Shane's Avatar
Thank you for the explanation, you learn something every day and I stand corrected. I have found surprisingly little about the Yaris' rear suspension except for advertising jargon and was calling it as I saw it. Another thing I found surprisingly little information about was the availability of rear sway bars. So they make a huge difference on the car I take it?
Old 09-02-2007, 05:47 AM   #14
WolfWings
WolfWings's Avatar
Changed the car from being squirreley and 'squiggley' when in extended turning (sweepers or doing figure-eights around a pair of orange cones in a parking lot) to taking a quick 'set' under load and being very easy to control with throttle-adjustments and responsive to turning. Exactly what you'd expect from an unstiffened chassis suddenly getting properly stiffened, much more than just a rear sway bar would normally grant on a FWD car.
Without the sway bar the car felt like it was near-constantly under torque steer (the fuel cut-off deceleration causing it even under engine braking at highway speeds) but once I had the sway bar put on what I thought was torque steer turned out to just be how loose the rear chassis was magnifying things to very noticable levels.
Hell, without the bar I felt unsafe doing my figure-eight practices to get used to how the car handled. I couldn't get myself to break 25mph. Once I put it on I had to stop when my passenger/friend started complaining about the alternating side-to-side G-forces I was pulling off doing 35-40mph figure-eights for ten seconds non-stop. Car feels much more chuckable, very much like my 89' Corolla FX used to feel, or my 86' Civic Hatchback felt.
Old 09-02-2007, 07:22 AM   #15
Motorhead6T5
Motorhead6T5's Avatar
Drives: 07 NCP96
If you've installed rear springs you figure out their is a lot of flex in the torsion beam,and the rear spring perches will move independantly.
Motorhead6T5 is offline   Reply With Quote
Old 09-02-2007, 11:35 AM   #16
largeorangefont
Break'em off some.
That is the point.
Old 09-02-2007, 07:51 PM   #17
CF-Shane
CF-Shane's Avatar
Sweetness. I feel a lot better about this then. Anyone know of a proven good front/rear sway setup and where to buy them?
Old 09-02-2007, 08:26 PM   #18
black2yaris
The Man In Black Lives
Drives: Black Sand Pearl L/B 'o7
TRD rear sway & Tenbe front strut . I got the rear one now am getting the front this week.....
black2yaris
The Man In Black Lives!
2007 2 door hatchback in Black Sand Pearl, A/T,rear spoiler,front & rear JDM badges,TRD CAI,TRD rear sway bar,exhaust tip,sill protectors,heximats,under dash blue LED's,short rubber ant,rear bumper protector,Toyota thin 7 spoke alloy wheels,pwr pkg,ABS,side curtain airbags,rear defogger,fog lights,mud guards,TYC tail lights,shift knob,tint all windows,security sys,keyless entry,clear paint protection all exposed front surfaces,TRD fuel cap,rubber dash & g/b mats
black2yaris is offline   Reply With Quote
rear fog light and tuned rear lights lefti696 Cosmetic Modifications (Exterior/Interior) 0 11-09-2006 03:06 PM
