Old 09-15-2007, 09:58 AM   #19
03Z33
03Z33's Avatar
Drives: TCR10
Very nice Joseph! Glad to see you got them
Old 09-15-2007, 02:11 PM   #20
JosephDoc
Drives: 07 Yaris 3D
Ok.. you guys know why I am going with SSR? It is all Jeff's fault!
JosephDoc is offline   Reply With Quote
Old 09-15-2007, 02:32 PM   #21
kimona
kimona's Avatar
Drives: 2014 White VITZ
Originally Posted by JosephDoc View Post
16"... with different offsets on front and back, and on 205/50/16 Bridgestone RE750.
Well, the front and rear wheels have same off set, but the trick is on different center pieces to fake the "stagger" and "deeper lip" look at back. (thanks to James @ Tanabe).
It is a custom setup up and this a business mai-do back to Tanabe.
Well, that's interesting. But, I don't understand why you would want to "fake the stagger" and have your wheels look deeper in the back when you could have taken advantage of the staggered look you were going for and actually staggered the offsets. Just about every set-up Vitz I see in Japan staggers offsets by 5 to 10mm's.
BTW, what offset did you decide on when you had the wheels built?
Old 09-15-2007, 07:56 PM   #22
JosephDoc
Drives: 07 Yaris 3D
Stagger set up proly won't help anything to this car, and fake stagger is a fashion in Japan!
True, plus me and Tanabe guys just want to have more fun this car. The goal is making it a fashion toy on street and also allow tire rotation possible as a daily drive car.
So here is the recipe:
16x7J+39 on front and rear, with Std & Shallow faces for front and rear.
205/50/16 Bridgestone RE750 87W 340AA
On Tein Coilover - Basic
*The tire size will not work if spring-lowered!*
The front tires are flushed with front fender (maybe 1+mm outside). Rear upper portion of fedner has 1 finger gap with the tire because of the round tire sholder, but wheel lip-flang is acutally flush with the fender. Bottom portion of rear tires stick out 15mm off o/e mud guards.
I was planning to insert 10mm spacers at back but since the rear bottom tire sticks out 15mm off the mud guard edge... no_go on this.
Hope this info help some to get nice JDM wheels.
Joseph
Old 09-15-2007, 11:28 PM   #23
kimona
kimona's Avatar
Well, the stagger just makes things look a little more even back to front. Many Japanese go with a set-up like ET42mm front and ET37mm rear, for example.
You said that you have ET39mm back and front, but that the rear wheels are designed to look deeper. So, the front and rear wheels are in fact different even though they have the same offset... is that correct? With this in mind, how can you rotate? (I'm not a fan of tire rotation anyway, but you mentioned it, and it doen't make sense to me with your design choice).
Now that you know how ET39mm fits the Yaris with 205/50 rubber, would you have chosen a slightly higher offset if you could do it over again?
Yeah, if the tires stick out way past the rear mudguards, it would look kind of stupid.
Old 09-16-2007, 04:30 AM   #24
JosephDoc
Drives: 07 Yaris 3D
Yeah, same off set but rear has deeper lip (1+" vs 1.5+" front/back) because it uses different thickness of center piece. The rotation still have to done through re-mounting the tires. It is good to have free labor service since I work in the shop.. heehee.
Hmm... more about off sets.. I would not make any adjustment on this up since all wheels flush out with fenders. Tires stick outside of the mud guard is pretty normal these days because autobody curves inward from fender to lower edge of the the body and especially our cars are extra rounded.
I can't find my book now but I remember in HyperRev108 recommends +37 on 16" wheels, and dont forget that offset accuracy varies depending on wheel manufacturers. For show cars, I love to see wheels have minimum gaps between calipers and the wheel spoks, and also allowing max lips. I think lowering to +33 on this wheel on the front is possible.
My opinion only
Old 09-17-2007, 01:57 AM   #25
DuckinOut
QUACK~!!!!!
DuckinOut's Avatar
Drives: Yaris LB
Send a message via AIM to DuckinOut
those are SICK . damn you, you beat me to ordering them rims . haha, it's ok, i've got something rare coming in soon . hehe
" ... I don't follow, thus i reign SUPREME . The only time i follow is when i follow my dreams ... "
DuckinOut is offline   Reply With Quote
Old 09-17-2007, 07:06 PM   #26
yalease
Drives: 2008 Yaris HB
need to save up and get some of these wheels.. they're niiice!
yalease is offline   Reply With Quote
Old 09-27-2007, 07:19 PM   #27
ItzyVitzy
Drives: 08 Yaris Sedan
Those are sick. I want to get the old school MK-II's.
ItzyVitzy is offline   Reply With Quote
SSR wheels on LB. joey1320 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 06-30-2007 02:49 PM
Feedback on these wheels BulletProofAuto Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 06-04-2007 08:09 PM
Buddy Club Wheels BulletProofAuto Sponsors Classifieds Area 8 10-19-2006 06:55 PM
