Old 09-14-2007, 10:52 PM   #1
John_v63400
Drives: 2007 Yaris 4dr. S
Tenabe Springs tire rub/bad on sedan
1 week after or so after I installed my springs, Im rubbing bad on every little bumb, my 18's are rubbing on the inner part of the wheel where the fender rolls inwards.
Can i grind it off with out N E problemos
Has anyone done this yet
NE sugestions
John_v63400 is offline   Reply With Quote
Old 09-15-2007, 03:51 AM   #2
eijikikimaru
Q(','Q)
eijikikimaru's Avatar
Drives: 3dr Meteroite
1.You can always take off the fender rolls. I believe it's 3 screws on each side plus those black push in the middle screw (5?)
2.Don't know what size tires you're running that may be a problem.
3.Get new shocks? The ones more suited for lowering springs
4. Tuck in your rims.
5. If you haven't had an alignment test
6. get smaller rims? (Just being an a$s sorry >.<)
Those are some suggestions. I personally think suggestions 2 and 3 will help solve the problem but hey...I'm not a master mechanic
eijikikimaru is offline   Reply With Quote
Old 09-15-2007, 08:24 PM   #3
rolling your fenders is another option...
Old 09-15-2007, 09:03 PM   #4
OgDogg
Gas Guzzler
OgDogg's Avatar
Drives: 07 Yaris Sedan S
I had this same problem. Installing a rear sway bar helps quite a bit, but won't solve your problem. I'm currently sanding away that inner lip on the fender but there appears to be some metal inside there making it difficult. I did manage to grind away about 1/10th inch or so from the inner fender. No rubbing yet, but I haven't had anyone in the back seat either... I'm running 18's with nf210s
OgDogg is offline   Reply With Quote
Old 09-16-2007, 03:42 AM   #5
John_v63400
Yeah im going to grind it off
Old 09-16-2007, 09:31 PM   #6
Lafiro
Drives: 06 Yaris Sedan
What offset are you running?
Old 09-16-2007, 09:37 PM   #7
YarisGirl82
His Name is "Chub" =o)
YarisGirl82's Avatar
Drives: '08 Yaris 3 Dr LB Meteorite
Send a message via Yahoo to YarisGirl82
i hate to interject, but I just ordered my '08 Yaris, and I haven't gotten it yet, looking to get my own aftermarket exhaust tip, can anyone tell me the muffler tip diameter on the '07? I know this has nothing to do with this thred, but you are online
YarisGirl82 is offline   Reply With Quote
Old 09-16-2007, 10:12 PM   #8
OgDogg
Gas Guzzler
OgDogg's Avatar
Let me know what you use and how it works out for you. :)
Old 09-17-2007, 06:11 PM   #9
yalease
Drives: 2008 Yaris HB
u can also do some good allignments. Anytime you lower a car, change a wheel, your allignment will be off. That's something you'll have to expect.
yalease is offline   Reply With Quote
Old 09-18-2007, 05:58 PM   #10
vacantj
Drives: Yaris 4Dr sedan
I just got my tires/wheels mounted and I'm rubbing also and it's on stupid all bumps and holes in the road - did grinding it workout? I might do that this Saturday...
vacantj is offline   Reply With Quote
Old 09-19-2007, 11:51 PM   #11
MR. CANTON
Drives: Yaris Sedan
well i have the same problem with my 17" when i put ppl in my back seat and i have the speaker box in the trunk it touches. but i was hoping to put the Tein S tech springs it suppose to be like 2" drop back and front but i really dont know what to now that urs rel touching still. i was hoping the spring may be stiffer but how much inches is urs lowered by because if u cut the inner lip in the fender isnt there is pssibility of cutting your tyre?? im not sure im just asking because i would like to nkow what to do also
MR. CANTON is offline   Reply With Quote
Flint Mica S Sedan, Bronze Konig Helium, NF210 Springs, und Tint flint_mica_manual Photo-Video-Media Gallery 6 05-09-2007 02:25 AM
LB and Sedan springs goodin Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 03-05-2007 08:28 PM
