![]() ![]() ![]() ![]() Drives: 2007 Yaris manual dark silver Join Date: May 2006
Yaris speed turns
I'm wondering whats the fastest you've gone in a sharp turn(what angle have you) someone told me that a mini cooper can go 45mph on a sharp turn (which i think is bs but...) I think i've gon 30mph but i have a stock suspention
(your definition of a sharp turn)
7 Color Tach Fujita Intake Momo pedals Shift knob and boot. Full TRD SSK. Blitz exhaust Megan Lowering Springs (Next is DC Header) Last edited by KSIbucky; 09-22-2007 at 07:58 PM. Reason: i hope this makes sence |
Back in USA in days!
I've taken a 90 deg turn doign 20 to 25 in the town I live in, I'm sure I would have spun out have I not had the tires and suspension drop I have
Kazera KZ-V Silver Rims, with 215-35-18 Kumho ESCTA ASX, TRD Springs, TRD Sway Bar, Fujita CAI, Blitz R-Vit i-Color, Blitz Throttle Controller, Megan Header, 2.25 Stainless Cat back Exhuast, 50 Series Flowmaster muffler, 6000k HID. |
i think you can go faster
7 Color Tach Fujita Intake Momo pedals Shift knob and boot. Full TRD SSK. Blitz exhaust Megan Lowering Springs (Next is DC Header) |
Mr Attitude
Drives: Blazing Blue 5 Spd Join Date: Jun 2007
Ask Jerkratt
It's scary to think that half the people surrounding you are below average...
Tires/suspension, I have done the 90degree turn in about the 20-30mph range. Any faster you will lose all traction and crash.
i've gone 40 in a 90 degree turn after my car was dropped and on stock tires
i've gone a pretty tight curve, probably like 100ft curve which almost goes almost 140 degrees, around 100km/h with megan coilovers and sticky tires.
![]() ![]() Drives: '07 YR 3dr Join Date: Jul 2007
Depends on how tight the turn is and how you drive. On hairpins, the fastest I can usually get around them is aounrd 40mph/60kph exit speeds, of course lower if the radius is smaller. On 90*/rightangled corners, gripping; I can usually hit them at 45mph/70kph before I understeer wide. HOWEVER, if you throw the car into a slide so that you have completed *most* of the rotation for the corner by the apex, you will less understeer-related problems. With this method, exit speeds ride to about 50mph/80kph. Note that is is not drift with crazy slip angles, and if you are using little/any opposite lock countersteer, you are loosing speed as your are trying to 'recover' the slide. Think more rally technique rather than drift. Those who have driven/played on dirt know that to drive a car fast in low traction situations require a different technique to overcome understeer, usually by rotating the car before the apex to reduce the steering input on exit and allowing to power out without running excessively wide. Well; once you reach the grip threshold of your tires, it becomes a low traction situation, just like drivingon dirt, but at much higher speeds...
Remember, the track's the only safe place to experiment... :-)
"I drive a silver egg" "Huh?" "An egg... You know; pretty much round, but with a pointy end; jeez..." |
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| What is the most economic speed for Yaris? | hans_fh | General Yaris / Vitz Discussion | 18 | 02-18-2007 04:34 AM |
| New Yaris Owner | Kiteless | General Yaris / Vitz Discussion | 8 | 08-02-2006 11:48 PM |
