View Poll Results: Handbrake use (Manual vs. Auto)
Manual - Yes I use the handbrake 29 63.04%
Manual - No I don't use the handbrake 2 4.35%
Auto - Yes I use the handbrake 8 17.39%
Auto - No I don't use the handbrake 7 15.22%
Voters: 46. You may not vote on this poll
Old 07-26-2006, 12:15 AM   #19
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
Its a great idea on autos to use the ebrake, especially on inclines. Im not 100% sure about newer tranny's but older makes had a parking pin for 'park' if you let the car roll forward onto the pin sometimes it would jamb and take a lot of force to get it back into gear.
mikeukrainetz is offline   Reply With Quote
Old 07-26-2006, 12:20 AM   #20
PSU Yaris
Drives: 2007 Toyota Yaris Sedan S
auto and always...i like the sound and plus it doesnt "clunk" into reverse if it rolled back a lil when i parked
PSU Yaris is offline   Reply With Quote
Old 07-26-2006, 09:40 AM   #21
Andrew Chalmers
Drives: NA
ok... this is the first time I've ever heard of anyone not using the handbrake... is this a common American thing? When you park - you use the handbrake. That's just common sense and taught at all driving schools & is a tested behavior in the driving exams.
Is there something I'm unaware of?
Andrew Chalmers is offline   Reply With Quote
Old 07-26-2006, 12:29 PM   #22
ChinoCharles
Drives: LB
Holy push-your-nose-up-in-the-air. Excuse us, Mr. Chalmers. Would you like a crumpet to go with your apparent social ineptitude?
For MANUAL, you should always use the handbrake. Yes, you can leave it in gear in a flat lot and it probably won't run away on you, but all that weight applied right to the gearbox can't be good for your car.
For AUTO, I owned a Cadillac STS and my family has always been an automatic-only kind of crowd, and I have never once seen them use the handbrake and I myself never used the handbrake on my Caddy. It never rolled away and the tranny never exploded.
Granted, I never went to driving school. I'm admittedly less-than-proper.
Old 07-26-2006, 12:44 PM   #23
rstb88
rstb88's Avatar
Drives: Silver Hatchback
On June 23, 2006 I recently completed a drivers course and NO WHERE in that book did it state you have to use the ebrake. And my test person never checked to see if the ebrake was used.
"Automatic carwashes are like Hookers........are you sure you want to use it next???? (Jer)"
rstb88 is offline   Reply With Quote
Old 07-26-2006, 02:23 PM   #24
Bones
Bones's Avatar
Drives: 07 Yaris S Type
For auto, when you put the gear into park a SMALL pin in the tranny engages.
The proper way when you're parking is:
1) Press on brake (of course)
2) Engage parking brake
3) Shift to park
The proper way when you're moving from park
1) Press on brake
2) Shift to drive or reverse
3) Dis-engage parking brake
This way the car won't move, especially when you're on a hill, and lean/ stress the pin inside the tranmission
Bones is offline   Reply With Quote
Old 07-26-2006, 02:24 PM   #25
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Drives: 09 Yaris LE, H/B, auto
Oh I though the question was do you use your hand brake to PARK...
as in drive the oposite direction steer in, couter steer, steer in again (over steer) and yank up the hand brake and spin the car 180 degrees into the parking space.
Either way.
07WYarisRS is offline   Reply With Quote
Old 07-26-2006, 04:32 PM   #26
Chaad32
Chaad32's Avatar
Drives: 2007 Liftback
Good one 07WYarisRS....that is what I use mine for.
2007 Liftback
Blazing Blue
Cold Weather, Convenience Package, Arm Rest,
Floor mats, Weathertech vent visors
Chaad32 is offline   Reply With Quote
Old 07-26-2006, 05:00 PM   #27
swng
swng's Avatar
Drives: 06 3-dr auto RS
Originally Posted by rstb88
the auto adjuster is on the rear brakes but has nothing to do with the hand brake itself. if you go in reverse and do a series of quick stops(don't have to go fast) it cause the star adjuster in the drum to click one notch per stop, which adjusts the pads to sit correctly against the drum in the even of braking
But you may also use the handbrake to achieve that, right?
Please see: http://www.echodrivers.com/forums/vi...t=6455&start=0.
I am not trying to debate as (after reading the information you wrote) I have learned that the rear brake self adjuster has nothing to do with the handbrake itself. Thanks for that. I just think the information in the link may be relevant and may interest other members discussing on this thread.
Simply put, using the handbrake for parking may result in some good side effects which may include rear brake self adjustment.
As for whether the Yaris has a self adjusting handbrake, now I am not so sure. Probably some may have that though (please see the last post done on 06 Jan 06 through the quoted link).
Note: We have members from many parts of the world and they drive different versions of the Yaris. It's so hard to cover all bases .
swng is offline   Reply With Quote
Old 07-26-2006, 05:02 PM   #28
ECHOKnight2000
Small Car Lover
ECHOKnight2000's Avatar
Drives: A Super Car
I've always used the handbrake since I could drive and still do use my handbrake and I have an auto...my parents use it so...not to say they are always right, but just growing up that way...I read that its hard on the tranny cause its holding the weight of the car, but maybe that's for manual than auto??? I remember I was test driving an xB and the sales guy was with me and when I was done, out of habit I put the handbrake on, he was like you don't need to do that...I was like why? I guess you don't need to do it with an auto but I just do it out of habbit, yes I'm crazy!
P.S. does any one know if it makes a difference with an auto?? I wouldn't think so...maybe i'm a caution freak.
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will.
ECHOKnight2000 is offline   Reply With Quote
Old 07-26-2006, 05:28 PM   #29
swng
swng's Avatar
3) Shift to park
1) Press on brake
Makes very good sense! I follow these steps myself. I would recommend to fellow members to follow them, especially when parking on slopes.
Note: I am only recommending these steps. In the community where I live, I believe there are lots of people who do not use their handbrakes when parking, especially when they have automatic transmissions and when they are not parking on slopes. I personnally do not have a problem with that.
Old 07-26-2006, 06:51 PM   #30
Chaad32
Chaad32's Avatar
3) Shift to park
1) Press on brake
I agree with you....makes good sense.
2007 Liftback
Blazing Blue
Old 07-28-2006, 08:39 AM   #31
Andrew Chalmers
Drives: NA
What did I say that was offensive ? In my country we have a standardized testing/licensing/learning system - and that is what everyone is taught. I asked a question - where was the holy push your nose up in the air/social ineptitude?
Old 07-30-2006, 07:03 AM   #32
Chaad32
Chaad32's Avatar
Good to see that most of the manual people out ther are using the handbrake. I'v started using it on my Auto and I do believe it is better for the tranny.
2007 Liftback
Blazing Blue
Manual shifter Mod.... hoahmaru Cosmetic Modifications (Exterior/Interior) 28 04-07-2014 05:05 PM
Is the 2006 Yaris Manual stick leather wrapped or not? hoahmaru General Yaris / Vitz Discussion 21 10-30-2008 08:14 AM
Finally drove the manual! drdavidr4u General Yaris / Vitz Discussion 2 06-14-2006 08:32 PM
No Option Combination #B for Manual Liftback???? Chickon New YARIS Purchase Forum 22 05-20-2006 12:49 AM
